Metal Pressure Plate for Super 8 Cartridges.
#1 Brian Drysdale
  • 5343 posts
Posted 16 January 2016 - 04:23 AM
This metal plate may be of interest to those concerned about the precision of the plastic pressure plate used on Super 8 film cartridges. You remove it before sending off your film for processing
http://www.gkfilm.de...tte/beschr.html
Edited by Brian Drysdale, 16 January 2016 - 04:23 AM.
#2 Tyler Purcell
Tyler Purcell
  • 4463 posts
Posted 16 January 2016 - 02:27 PM
Sweet! I always heard of something like this, but never knew where to nab one! :) Thanks for the link!
#3 Moises Perez
Moises Perez
  • 55 posts
Posted 17 January 2016 - 10:17 PM
Does it work?
Has anybody used it?
Is it worth the investment?
MOY
#4 S8 Booster
S8 Booster
  • 132 posts
  • retired
Posted 17 January 2016 - 11:12 PM
The pressureplate was originally developed to try to correct / compensate for production failures with the kodak cartridges. In the early 2Ks the film jammed, film waved & breathed heavily. The PP did i prove a little apaert from jamming which was a direct assembly failure.
If your camera is worn do not expect euureka experience but it has the potential to improve imperfectio. It eill run a little heavier.
There is some promo clips om thr net somewhere. Check thrm out an see for your self.
Edited by S8 Booster, 17 January 2016 - 11:15 PM.
#5 S8 Booster
S8 Booster
  • 132 posts
  • retired
Posted 17 January 2016 - 11:34 PM
Some "Frame Master" demo klips here:
http://www.andecfilm...o-bildstand.htm
#6 S8 Booster
S8 Booster
  • 132 posts
  • retired
Posted 18 January 2016 - 09:10 AM
Better clip: V200T with and without the "Frame Master": http://www.andecfilm...gs/neg_7274.mpg
#7 Brian Drysdale
  • 5343 posts
Posted 18 January 2016 - 10:00 AM
You have to use your full real name in the forum, it's one of the rules. You have to contact Tim Tyler the site owner to make the change.
#8 Anthony Schilling
Anthony Schilling
  • 1065 posts
  • Portland, OR
Posted 18 January 2016 - 10:26 AM
I have one but haven't used it for a while. The idea is to reduce breathing and jitter, and it does help. The downside is if you're using thicker emulsions like Vision, and your cameras motor isn't working to its full potential, the film may not advance. I had that happen twice, you,re done shooting only to find you still have 50ft of film in the camera.
#9 Tyler Purcell
Tyler Purcell
  • 4463 posts
Posted 18 January 2016 - 02:10 PM
Ahh, that makes sense as a lot of pull-down claws aren't designed to pull through that added friction.
