"Soft focus" technique?
depth of field focus close ups
12 replies to this topic
#1 Adam Weinberg
Adam Weinberg
  • 13 posts
Posted 29 January 2016 - 09:04 PM
hey everyone - first post here! so i thought i'd ask a question that has baffled me for years.. and might have a very simple explanation (i'm a professional cameraman who has been doing this for a decade, so i'm a little embarrassed to be asking):
quite often in both large scale TV and film productions i'll notice on CUs of actor's faces with shallow DOF that the focal point is a good inch behind their eyes - the tops of the actor's ears are tack sharp, but their eyes and face are slightly softer. when i first started noticing this i assumed it was a mistake / sloppy focus pulling, assuming that an actor's eyes should always be their sharpest feature in a close up, but then i noticed this "technique"(?) more and more often and realized it must be intentional.
it occurred to me that DPs might be going for a soft focus effect on the face because it's more flattering on the subject, but then .. why is this an effect i see so inconsistently, even within a particular film? curious how obvious of an answer this might be. be gentle, i'm self taught and never went to proper film school.
  • 20471 posts
Posted 29 January 2016 - 09:23 PM
The goal is generally to have the eyes in focus so it's not intentional in most cases. The main reason is that actors tend to lean forward while talking and the focus puller got a measurement when the actor was sitting or standing straighter. And focus pullers worry about over-compensating and pulling too close, in which case the focus could end up in the air in front of the actor or the tip of the nose.
Another less common reason is just that the actor has moved closer than minimum focus on the lens.
#3 Adam Weinberg
Adam Weinberg
  • 13 posts
Posted 29 January 2016 - 09:31 PM
wow - that's what i initially thought was the explanation seeing as you could use a Pro-Mist filter or something of that nature to flatter the subject  .. but if this isn't a technique than i'm shocked at how often i've seen shots with this mistake make the cut in high profile films!
#4 David Mullen ASC
  • 20471 posts
Posted 29 January 2016 - 09:34 PM
There are some rare cases where a DP will have a focus puller let a face go a little soft in focus to be flattering but it is far more common to use a diffusion filter instead so that the eyes can be in focus. Out of focus eyes can be distracting.
#5 Adam Weinberg
Adam Weinberg
  • 13 posts
Posted 29 January 2016 - 09:42 PM
thanks for your help david - glad to hear i haven't been oblivious to some strange focus technique for the past decade.
#6 Bruce Greene
Bruce Greene
  • 716 posts
Posted 31 January 2016 - 11:55 AM
I think this out of focus effect is almost always unintentional.
I think it's especially common when focus pullers use a video monitor with focus peaking to confirm the focus... It's just not accurate enough.
#7 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 31 January 2016 - 04:03 PM
If the actor's head is behind a dark background and there is no catchlight in the eyes, often the ears will pop into focus first on a focus puller's monitor due to the greater contrast around the ears. Especially on a difficult shot there's a tendency to latch onto the first sharp thing you see, so focus pullers need to watch out for that when pulling from a monitor. It takes some confidence to simply know where the focus is and not go hunting for focus when nothing looks pin-sharp on the small monitor due to low contrast.
#8 Stuart Brereton
Stuart Brereton
  • 3491 posts
Posted 31 January 2016 - 09:52 PM
Aside from the false positives that focus peaking occasionally gives, on a 5" monitor, just about everything looks sharp. Ever shortening schedules have meant that ACs don't have the time to measure distances like they used to, and they are always under pressure to 'shoot the rehearsal'. Hence the reliance on the monitor, and all of the inaccuracies that come with it.
#9 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 01 February 2016 - 03:51 AM
I had a young 1st AC who works on a lot of $2m features tell me that apparently name talent these days hate it when you tape out, especially with soft tape. She would know better than me, since I never really worked on features or tv before I moved on to shooting. I think that's rather odd, but if true I guess it would certainly explain some things.
#10 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 01 February 2016 - 05:12 AM
The only times I had this effect when I was a focus puller.. was when the actors screwed up...
#11 Stuart Brereton
Stuart Brereton
  • 3491 posts
Posted 01 February 2016 - 12:41 PM
I've never heard of that. Don't see why they should care. Having a hard tape thrust in their face from 6 feet away, as I've seen many ACs do, is another matter.
#12 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 01 February 2016 - 05:27 PM
Yeah, that's not so good. In the past, I would throw out hard tape at waist level and eyeball any offset. But I always liked using soft tape more than the laser for repeatable dolly moves where we had marks. Never liked shining a laser near the face so I'd usually aim at the chest and again eyeball offset. Whereas with the soft tape, you really had precise marks to the eyeball. But then, the projects I worked on almost never had a Cinetape. Maybe that makes a difference?
#13 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 01 February 2016 - 06:00 PM
This is British sarcasm by the way !
