Shooting anamorphic with C300 Mark II
#1 Julie Angelo
Julie Angelo
  • 6 posts
Posted 02 February 2016 - 09:16 PM
Hello everyone! I have a question concerning shooting anamorphic with the C300 Mark II. First is it possible ? And if it is, how can I see the image desqueezed on the LCD/VF ? I've looked at the menu and I can't find the answer. Or is there a desqueeze option on the monitor (I don't know which one I'll use) I'm connecting to the camera ?
Thanks a lot !
Julie
#2 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 02 February 2016 - 09:24 PM
Possible Yes. I dont think the C300 has an option for 2x anamorphic as far as resolution but you could should 1.3x with 16x9 to get 2.4:1.  Unfortunately unless you have a PL mount you would be stuck with using adapters on the end of the lens, there are a lot of really good write ups about doing this.  If you have PL I think there are a couple options for renting 1.3x Anamorphic Primes.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 03 February 2016 - 01:39 AM
There's no desqueeze option in-camera as far as I can tell. But you can still just put a scope lens on the camera and desqueeze in post. Most newer on-board monitors and EVFs should have a desqueeze option for framing, but it's not totally necessary. You'll want one that has customizable frame lines.
#4 Julie Angelo
Julie Angelo
  • 6 posts
Posted 03 February 2016 - 09:26 PM
Thanks a lot !  So does it mean that even with a PL mount I won't be able, unless I have a monitor with a desqueeze option, to see the image desqueezed on set ?
  • 1
#5 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 03 February 2016 - 09:51 PM
There are some monitors and view finders that will do the desqueeze with a passthrough so everything down stream of it will then be de-squeezed.  I think the new Zacuto eyepiece does that.  But the majority of monitors I use will do the desqueeze very easily.  Pretty much any SmallHD will handle it.  I use the AC-7 which is affordable.  And the Ikan 17" field monitor will do it as well and its pretty affordable.
#6 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 03 February 2016 - 09:53 PM
Correct.
#7 Julie Angelo
Julie Angelo
  • 6 posts
Posted 04 February 2016 - 10:29 PM
Great thank you for your help!
#8 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 05 February 2016 - 04:54 AM
To give you some idea of what you'll have to deal with to get a 2.39:1 aspect ratio:
Kowa 2x 40mm anamorphic on C300 Mk1 1.78:1 (Squeezed)
Kowa 2x 40mm anamorphic on C300 Mk1 3.56:1 (Unsqueezed)
Kowa 2x 40mm anamorphic on C300 Mk1 2.39:1 (Unsqueezed and Cropped)
You can see how much image you are losing on the sides once you crop to 2.39:1. You'll really need to have precise custom frame guides on your external monitor to even know what your final frame will be.
#9 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 05 February 2016 - 05:01 AM
On the other hand, once you have the correct frame lines, it's not too hard to compose even with a squeezed image:
So I guess I would prioritize frame lines over desqueezing, if you have to pick one over the other. Hopefully, you can have both.
