European Ultra 16
45 replies to this topic
#1 Tom Chabbat
Tom Chabbat
  • 83 posts
  • Paris, France
Posted 10 February 2016 - 12:42 PM
Hi all,
I was curious to know, is there anyone here shooting in the ultra16 format in Europe ? And if so, how do you get your conversion, film processing and transfer ?
From the few information I succeed to gather it seems the only U16 friendly facilities are all based in the U.S.
The most recent post of european filmmakers I found here comes back to more than four years ago, so I'd be curious to know if things evolved since, as I'm seriously considering adopting it.
I'd very much like to see this format stepping a little more into the light.
Edited by Tom Chabbat, 10 February 2016 - 12:43 PM.
#2 Nicholas Kovats
Nicholas Kovats
  • 526 posts
Posted 10 February 2016 - 01:25 PM
Tom,
Doug Palmer in the UK has documented his Ultra 16 modifications to his Bolex camera, i.e. http://www.filmisfin...amera-sprocket/. I can't locate his blog posts regarding his U16 conversion of a Bolex projector. He can be contacted at
doug@filmisfine.co
He might have a handle on U16 processing and transfer. But any lab or scanner system with a sprocketless drive can provide these services. Those are the two fundamental lab/scanner requirements for my non-standard UltraPan8 Bolex camera system and I utilize them both here in Toronto, Canada.
Nicholas
#3 Will Montgomery
Will Montgomery
  • 2164 posts
  • Dallas, TX
Posted 10 February 2016 - 03:03 PM
I've been shooting U16 for years on my Scoopic, but have yet to transfer it properly since I've usually have used Spirits and they don't see between sprocket holes. I have many feet of film waiting to be re-transfered properly and get the entire image.
#4 Roberto Pirodda
Roberto Pirodda
  • 113 posts
  • Italy
Posted 19 February 2016 - 06:47 AM
i have enlarged the gate of my 16mm Bolexes to full widht of the film , then i can chose to telecine Ultra16 or Super16 area. I have my own 3 CCD datacine frame by frame scanner up to 2,5K
#5 Tom Chabbat
Tom Chabbat
  • 83 posts
  • Paris, France
Posted 19 February 2016 - 10:35 AM
I'm curious, how did you do it ? Do you have your own lathe or mill ? Or did you go to some workshop ?
Which one of these formats you use the most in the end ?
#6 Roberto Pirodda
Roberto Pirodda
  • 113 posts
  • Italy
Posted 19 February 2016 - 12:54 PM
Hello Tom, i have both lathe and mill, it is a UNITOR unit made in Italy. I use it for my business about photographic equipment repair ( i am not only a cinematographer). About scanning, i usually scan in S16 because it is a more usable format. Unfortunately for U16  in the edge of the film there is the film code so i cannot use total widht of the film , otherwise i could achieve a wider aspect ratio vs S16
#7 Doug Palmer
Doug Palmer
  • 382 posts
Posted 20 February 2016 - 04:45 AM
Roberto, I'm currently converting another Bolex (non-reflex) to ultra-16.  I was wondering whether to enlarge the gate to the full width, ie. wider than 1.85:1.  Maybe something like 2.2:1.  As you mention,  the edge numbers are the problem on most film stocks. But maybe if we put our concerns to Ferrania and others, they would keep those numbers away <_<  Wittner doesn't do the numbering on 200D.
But my query is this:
Did you have any problem enlarging the Bolex gate to the full width and how wide is that please?  Is the film held flat and steady,  as before ?
#8 Doug Palmer
Doug Palmer
  • 382 posts
Posted 20 February 2016 - 04:48 AM
By edge numbering, I really mean those dreadful code numbers that appear every so often between the perfs.
#9 Roberto Pirodda
Roberto Pirodda
  • 113 posts
  • Italy
Posted 20 February 2016 - 07:03 AM
yes, those hateful edge codes... anyway, i have already converted a non reflex Bolex. I left 1 mm per side to support the film, so the real width is 14mm. The film can be flat and steady with proper spring tension of pressure plate. I would like to enclose  an image but here it is impossible
#10 Mark Dunn
Mark Dunn
  • 2896 posts
Posted 20 February 2016 - 07:08 AM
It's not edge-numbered because it is cut from a wide roll of stills film. 16mm. is edge numbered so that a neg cut can be matched to a workprint.
#11 Phil Rhodes
  • 12406 posts
Posted 20 February 2016 - 08:35 AM
And when was that last actually done?
Has it been done in decades?
#12 Dirk DeJonghe
Dirk DeJonghe
  • 622 posts
  • Kortrijk,Belgium
Posted 20 February 2016 - 12:49 PM
Negcutting is still done, a new feature film is planned for later this year, they want negcut, traditional film grading and later a full scan of the cut negative, Baselight grading and DCP etc. Keykode numbers are essential for both negcutting and rescanning of selects.
#13 Phil Rhodes
  • 12406 posts
Posted 20 February 2016 - 12:50 PM
Yes, but - on 16mm?!
#14 Robert Houllahan
Robert Houllahan
  • 1674 posts
  • Providence R.I.
Posted 20 February 2016 - 12:57 PM
Our Cintel Telecine, and both our Dynamic Perf (sprocketless) 4K Xena and our Pin Registered 5K Sequential RGB Xena can scan Ultra-16mm up to UHD or 4K.
DCS may be selling their Xena machines in Europe soon.
I just bought a Spirit 2K and I will see if there is any way to run Ultra-16 on it when we get it from LA next week.
#15 Doug Palmer
Doug Palmer
  • 382 posts
Posted 20 February 2016 - 01:40 PM
I understand about the edge numbers for conforming of workprint, but I don't know why Kodak has to put another smaller code number further in every foot or so.  So it prevents that bit of emulsion being used for image.  And I don't understand why the other edge numbers have to be so large. They could be easily half the size and still be OK to use for matching.
#16 Robert Houllahan
Robert Houllahan
  • 1674 posts
  • Providence R.I.
Posted 20 February 2016 - 01:46 PM
I think the issue is that the Edge Coding system that Kodak uses would have to be re engineered significantly to make the code and numbers smaller, and that is not likely to happen. Also the larger barcode and numbers make them easier to read by eye or machine in the event of some edge fogging.
#17 Doug Palmer
Doug Palmer
  • 382 posts
Posted 20 February 2016 - 01:53 PM
That's really wide :)   and encouraging if you say the Bolex can handle it.  So you think it should be OK if  the camera is working well ?  Mine is a flat-base H16M which runs regular 16mm very smoothly.
It's a shame about the edge codes.  If more people use ultra-16 Varispect etc maybe manufacturers will take notice.
#18 Doug Palmer
Doug Palmer
  • 382 posts
Posted 21 February 2016 - 06:35 AM
I do feel though rather nervous filing the gate out to that extent. It could void the Bolex guarantee :D
#19 Roberto Pirodda
Roberto Pirodda
  • 113 posts
  • Italy
Posted 21 February 2016 - 03:09 PM
Well Doug, if your Bolex is still in guarantee  better not alter it :-) anyway my bolex round base works great, it is not as steady as EBM but it has been so even  before modification. It has the older pull down claw mechanism with steel gate .
#20 Kenny N Suleimanagich
  • 902 posts
Posted 21 February 2016 - 10:54 PM
It has! Though certainly not on the scale it was done before.
