Question about lighting and the kelvin numbers...
#1 scott karos
scott karos
  • 41 posts
Posted 11 February 2016 - 06:11 PM
I've started to incorporate lights more into my projects. Before I wouldn't even bother and just use whatever available light was there.
Before for white balance I would just use the settings like Daylight, Fluorescent, Cloudy, etc. But I'd like to start using the kelvin settings along with my lights.
For example, the lights I have are balanced for I think 6500 Kelvin according the little manual the lights came with. Does that mean I would go into my camera and set it to 6500?
#2 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 11 February 2016 - 06:25 PM
If you want your lights to be even white yes.  Color temperature settings can also be used to effect your lights effective color in the final shot.  I have often mixed tungsten and LED and balanced somewhere in the middle to get warm and cool contrast.  Of course shooting raw I can push it in any direction in the grade but you get the idea.  Often you have to deal with other lights in a scene, like florescents, in which case you would want to use color correction gels on your lights to match the florescent color temperature for consistent white, and balance for that in camera.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 11 February 2016 - 08:00 PM
Theoretically yes, though in practice this may not give you a perfect white balance. It really depends on how accurate the light source is that you are using and the camera as well. If the source in question is an LED then chances are it will be quite a bit off from whatever the manual says. The only way to know for sure is to test and see.
Sounds like you may be using a Canon DSLR or C series camera, you can also do a manual white balance on those which will probably give you the best result quickly. The other option is to use gels like CTO, CTB, Minus Green, and Plus Green on your light to match it by eye to natural daylight. This will require some experimentation on your part.
