Arri Conversion Kit AS18 to M18
#1 Shachar Alfie
Shachar Alfie
  • 16 posts
  • Israel(Middle East)
Posted 15 February 2016 - 03:57 AM
hi,
can I use the Arri Conversion Kit AS18 to M18 for converting my Arrisun 12 Plus to lensless arrimax or
will it only convert as18?
#2 Stuart Brereton
Stuart Brereton
  • 3365 posts
Posted 15 February 2016 - 11:06 AM
Try this:
https://www.arri.com...rvice/lighting/
#3 Shachar Alfie
Shachar Alfie
  • 16 posts
Posted 16 February 2016 - 03:12 AM
Thank you Stuart Brereton !
the official answer is NO but maybe it can still be done ?
The conversion kit is only to convert an AS18 to an M18.
It is not possible to use it with the old AS 12 Plus.
Mit freundlichen Grüßen / With kind regards
ARRI Application & Services
(Senior Service Manager)
ARNOLD & RICHTER CINE TECHNIK
GMBH & CO. BETRIEBS KG
#4 JD Hartman
JD Hartman
  • 1773 posts
  • Edison, N.J. U.S.A.
Posted 16 February 2016 - 06:30 AM
As18 and M18 reflectors mount at different positions in the housing. of the AS18.  I'd doubt the the means exist in an ARRISUN 12 to provide a mounting surface for the M18 conversion reflector.
#5 Guy Holt
Guy Holt
  • 565 posts
  • Boston
Posted 01 March 2016 - 09:44 AM
Placement of the globe arc in the reflector is critical to optimizing the performance of each light and the ideal placement is different for each type of reflector.  The casting of the AS18/M18 has mounts for each reflector to optimize performance, the Arrisun 12 has mounts only for a par reflector. If I remember correctly the  ARRIMAX reflector of the M18 mounts forward of the par reflector, which would mean that the casting of the Arrisun 12 does not extend forward enough to fit the ARRIMAX reflector.   The AS18/M18 offer other benefits such as power factor correction in the ballast that make it worth while for you to sell the Arrisun 12  and buy an AS18 and the conversion kit ( use this link for more details.)
Guy Holt, Gaffer
ScreenLight & Grip
Lighting Rental & Sales in Boston
