Krasnogorsk M42 & Photo Optics?
11 replies to this topic
#1 Alex Fuchs
Alex Fuchs
  • 89 posts
Posted 01 June 2005 - 07:40 AM
Hi Dudes,
at the moment I get in touch with a Krasnogorsk 3 camera with M42 lens-mount. Can I mount normal M42 photo-optics (old German Democratic Rebublic stuff) on it and cause this some vignettes (don't really know if that is the right english term) than?
Regards Alex
#2 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 01 June 2005 - 08:30 AM
you will not get vinetting from using any m42 lenses that I know of.
#3 Struwwelpeter
Struwwelpeter
  • 20 posts
Posted 01 June 2005 - 09:12 AM
Nah, definately no vignetting. M42 lenses were designed for use with 35mm still cameras, they'd easily cover 16mm without issue.
#4 Alex Fuchs
Alex Fuchs
  • 89 posts
Posted 02 June 2005 - 04:59 AM
thank you dudes. but one more question: what is with the focal length of the 35mm optics. what focal lenght is it when I use it on a 16 mm camera. when I take a 50mm on a 35mm-camera does it mean, that I have a 25mm on a 16mm camera?
regards alex
#5 Freya Black
Freya Black
  • 4164 posts
Posted 02 June 2005 - 06:01 AM
regards alex
<{POST_SNAPBACK}>
Fraid not, you still have a 50mm lens whatever camera it is connected to. 50mm would of course be considered a bit telephoto in 16mm. This means that it is hard to get cheap wide-angle lenses for use in 16mm when using the M42 mount because 25mm lenses would just be what is considered normal in 16mm, so you would need a lens less than 25mm in size to get wide angle shots, whereas in 35mm cameras a 30mm lens would be wide angle!
The lenses stay the same size whatever they are connected to.
love
Freya
#6 Kevin Pham
Kevin Pham
  • 12 posts
Posted 28 February 2011 - 02:36 PM
Hi Dudes,
Regards Alex
Conversely, can you mount the Meteop 17-69 f1.9 to a Pentax camera for still shooting?
Thanks!
#7 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 28 February 2011 - 03:34 PM
Thanks!
Well it would physically fit, but the image circle projected by the lens is only just big enough to cover a regular-16 sized frame of film - it vignettes on super-16, so placed on a 35mm stills camera you'll end up with a small circular image in the middle of the frame, with a lot of black all around it!
#8 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 28 February 2011 - 05:56 PM
I'm not sure it would since it protrudes out into the mount quite a bit, it might break the mirror.
The Pentax m42 mount lenses are really great for that camera. The best shots I ever got with a K3 were using a Pentax Super Takumar 50mm.
#9 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 01 March 2011 - 02:41 AM
I'm not sure it would since it protrudes out into the mount quite a bit, it might break the mirror...
Ah - good point!
I'll rephrase that: Should physically fit with the mirror locked up safely out of the way! :rolleyes: Lol.
Unfortunately that means you'll no longer be able to see through the viewfinder what you're pointing the camera at, nor be able to see how badly vignetted the image is until after you've had the film developed. ;)
#10 Kevin Pham
Kevin Pham
  • 12 posts
Posted 19 March 2011 - 08:18 PM
If you use M42 Macro Extension tubes, I wonder if you could be able to use the Meteop on a M42 body/Camera with M42 adapter. Any thoughts?
#11 Ferdinand Casido
Ferdinand Casido
  • 5 posts
Posted 21 March 2011 - 02:44 AM
regards alex
The Field of View changes.
* For 16mm film, 50mm is considered a telephoto, 25mm is “normal” and 10mm is wide.
But I found that it is really hard to get ultra-wide lenses though.
Luckily my school has a 16mm Zenitar lens to get a wide enough angle for my shots. I couldn't use the stock lens (17–69 mm zoom) because of the minimum shooting distance with it was 6 feet (2 meters).
But I like the camera because I could of the M42 mount. I also used a 28mm Super Takumar. The images looked really nice.
#12 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 21 March 2011 - 08:33 AM
That's a great lens for the K3. Watch out if the gate has been widened for Super 16mm and the mount NOT re-centered which is common; you'll have more distortion on one side that looks odd.
The 8mm Peleng has too much distortion even on a 16mm camera IMHO unless you want that look.
