Of Frame Rate and Time Base
#1 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 22 February 2016 - 08:24 AM
Hey,
So I am facing a small problem on a project I recently shot on the Sony A7s 2.
The film is a combination of 24 FPS shots as well as some 100 FPS shots - the issue is that with every 100 fps shot the time base in the camera changes to 100 as well.
Now my editor is stuck with 2 different time bases of 24 and 100 respectively and claims that it is a problem to edit such footage as AVID sets one timebase for the entire sequence ?
Somehow I remember testing this out on adobe premiere and it worked fine..
Is there a work around for such an issue ?
Will there be a problem for me in the conforming process ?
Thank you for your help :)
#2 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 22 February 2016 - 04:09 PM
In Premiere you can select a new timebase for an individual clip by right-clicking on it in the media browser and selecting:
Modify>Interpret Footage>Assume this frame rate [23.976].
It will help if you separate the media on your hard drive into a 23.98fps folder and a 100fps folder. That way, when you import the 100fps folder you can 'select all' and change the clip properties all at once instead of one at a time.
Don't know if Avid can do this but in the worst case scenario, just put all the 100fps footage on a 23.98 timeline in Premiere, reset all the clips to 23.98, then transcode to a codec of your choice (Prores, DNxHD, etc.) and just deliver those.
#3 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 22 February 2016 - 06:00 PM
Thanks Satsuki
Thats helpful
