Faking day interior timelapse
#1 David Karger
David Karger
  • 2 posts
Posted 29 February 2016 - 10:37 AM
Hey everyone,
I have a challenging shoot coming up and would appreciate advice from anyone who has tried something like this.  I have to simulate a day interior time-lapse - basically just a room with shadows from a window pane and furniture tracking across the floor as if during an entire day.  I can’t do a real time time-lapse because we only have the location for one day, and have no idea what the weather will be doing - plus we want more than one take per day.  So here is my plan.  I would appreciate any input with regard to how it can be improved, or whether it might even work at all:
We are shooting at night, so as to control as much of the light as possible.  I am renting an Arri M18 to be our sun, and putting it on a small crane which will sit on a Matthews Doorway Dolly.  I am putting that dolly as far as possible away from the exterior wall I will be shooting the light through - probably around 25’.  The exterior wall I am shooting through will actually be faked by putting up duvetyne walls with a small gap, into which I will place the window pane I am using to cast shadows into the interior of the room.  I will balance the interior light and the “sun” by using some kind of fill lights inside the room - maybe Kinos or maybe tungsten lights with a little CTB to minimize the color differential between them and the HMI sun.  I will create the moving shadows by craning the M18 up and down while dollying it across the floor.  My plan is to add a small amount of atmosphere into the room with a DF-50 hazer, to try to make the sunlight streaming through the window somewhat visible.
My biggest concern is making the M18 look like the sun inside the room, and not like a big spotlight hitting the floor or walls.  I have experimented a little with smaller lights and it is pretty challenging to prevent this spotlight effect.  I think using the edge of the beam to cast the shadows rather than the center of the beam may be helpful.  But I would really appreciate any advice from anyone who has experience with this.  Thanks for your help!  Dave
#2 Phil Rhodes
  • 12407 posts
Posted 29 February 2016 - 10:40 AM
Whatever light you use, you'll need to ensure it fills the edges of the window frame you're projecting through. Often the shadowcasting abilities of a PAR are criticised, although it depends to some extent on the situation.
If the M18 won't do that from 25 feet, consider something else.
#3 Maximilian Motel
Maximilian Motel
  • 31 posts
  • Berlin, Germany
Posted 02 March 2016 - 10:33 AM
What are your plans regarding the placement of the M18? Have you looked at the Sunseeker app? I probably wouldn't trust it for precise placements of the light, but might give you a nice starting place.
