sony pmw f55 sensitivity raw
#1 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 01 March 2016 - 03:01 PM
Hi, anyone knows the sensitivity of the cam while shooting raw? THX
#2 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 01 March 2016 - 09:34 PM
RAW is always recorded at native ISO on the F55.. 1250.. with the R5 recorder..you can also record internally to SxS cards at the same time.. to which you can apply a LUT or what Sony calls Looks i.e. 3D LUT,s.. or user LUT,s if installed via SD card..
Edited by Robin R Probyn, 01 March 2016 - 09:35 PM.
#3 Mark Kenfield
Mark Kenfield
  • 1240 posts
Posted 02 March 2016 - 01:07 AM
Test. Test. Test.
I have an F5, and although the claimed sensitivity is 2000 ISO, it is actually only 1125 ISO. 8/10 of a stop slower than claimed.
You can see my tests here: http://dreamsmiths.com.au/blog/
Many people seem to have encountered similar issues with the F55 needing to be 'overexposed' by a stop in order to be properly exposed. You need to test this to see. It isn't actually overexposure if you're simply exposing for the actual sensitivity of the camera (i.e. the point at which middle grey reaches it's appropriate IRE value for the gamma curve you're shooting with).
The new Sony's are exceptionally clean and noiseless when exposed properly, so you shouldn't have any issues with noise or muddy pictures if you test the camera in advance, and rate its actual sensitivity accordingly.
#4 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 02 March 2016 - 02:22 AM
Its RAW so you might as well over expose at least one stop anyway.. tons of data there. 16 bit .. etc..
#5 Olivier Martinez
Olivier Martinez
  • 33 posts
Posted 02 March 2016 - 05:30 AM
Thx guys!!!
#6 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 02 March 2016 - 06:05 AM
Easiest way is to use the preset REC 709/800 MLUT.. P1 I think it is in the MLUT menu (M is for monitor,) in your VF.. and just make it a bit hot..  IMHO
