opinion needed on source of problem
grain color shift x-rays
7 replies to this topic
#1 Phillip Mosness
Phillip Mosness
  • 101 posts
Posted 05 March 2016 - 01:26 AM
If anyone recognizes these problems, I’d be curious to hear.
I bought this film second hand so it’s impossible to know how it was stored before I owned it.
It’s the first time I’ve run across problems that looked like this, however, and I’m trying to determine what the problem was/is.
I’m tempted to say it got large doses of x-rays going through airport security, bit one roll seems to have come out fine.
All were Vision2 and 3 500T in 100’ loads in a Bolex super 16. A combo I’ve used many times with no problems.
Any ideas?
Thanks!
https://vimeo.com/157816781
Password: superprob
#2 aapo lettinen
aapo lettinen
  • 1220 posts
  • Finland
Posted 05 March 2016 - 02:45 AM
I have have exactly the same kind of problem with old unknown history 50D EXR except it was pumping red layer, not blue.  for example inconstant temperature on one side of the roll or pressure sensitization can do this.
the problem faded a little after about half of the roll but was there all the time at some extent.
I would not buy second hand films unless in very big factory sealed rolls so one can have a good test of each roll and depend on that the rest is in proper condition then. in case of 16mm, factory sealed 400ft rolls and then winding it down to 100ft loads
#3 aapo lettinen
aapo lettinen
  • 1220 posts
  • Finland
Posted 05 March 2016 - 02:49 AM
eBay short ends would be the worst: both unknown history and age AND short length, each roll have to be tested, usually not economical unless the rolls are almost full. like 380ft for 16mm or over 800ft for 35 for example
#4 aapo lettinen
aapo lettinen
  • 1220 posts
  • Finland
Posted 05 March 2016 - 02:50 AM
some of it still looks more like x ray damage, at 00.27 or so
Edited by aapo lettinen, 05 March 2016 - 02:51 AM.
#5 Phillip Mosness
Phillip Mosness
  • 101 posts
Posted 05 March 2016 - 05:49 PM
Aapo Lettinen "I have have exactly the same kind of problem with old unknown history 50D EXR except it was pumping red layer, not blue. "
I've never seen a red problem outside of the light leaks one gets when they load daylight loads in ....daylight. Those are usually on the right side of the frame and I at least know what happened.
I realize second hand film is a risk, but I've had such good luck over the years . With this batch it was the pulsing that was driving me nuts because a consistent problem could be worked with more easily, and they were still factory sealed.
I guess I shouldn't have left those rolls in the MRI  machine that one time. hehe
#6 Tyler Purcell
Tyler Purcell
  • 4473 posts
Posted 05 March 2016 - 06:39 PM
I can't imagine it being a problem with the film. I like the idea of it being exposed to xray.
If it were a camera problem or issue with the film itself, you would see a more consistent problem.
The "pulsing" leads me to believe it was hit with radiation from ONE SIDE of the film reel, which is why the other side of the reel was OK. Why one of the rolls survived is because it was being blocked by the other rolls and simply didn't get hit with AS MUCH radiation.
SO yea, I'm hedging my bets on xray.
#7 Richard Tuohy
Richard Tuohy
  • 484 posts
  • Daylesford, Australia
Posted 06 March 2016 - 03:47 AM
Looks like X-ray damage to me. Sweeping lines
#8 aapo lettinen
aapo lettinen
  • 1220 posts
  • Finland
Posted 06 March 2016 - 08:26 AM
yeah the sweeping leads to thinking that it is definitely external and most possibly x-ray.
the red layer is the most sensitive in film (least energetic photons) so it is logical that my issue is concentrated on that layer. that exr also had very green image but that is separate issue...
