How the Alexa really works
arri alexa sensor iso dynamic range ei digital camera
141 replies to this topic
#1 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 06 March 2016 - 01:37 PM
Hi guys!
After some research, I made a little chart one every rich man's favorite camera, the Alexa, which digs into how it really works. So I thought I might as well share it.
The content holds true for every Alexa I believe, since they all have pretty much the same sensors and algorithms (even the Alexa 65 I assume, who consists of three Alexa sensors merged).
On the right of the table are the only available curves to my knowledge, the LogC ones.
Every other curves isn't, but should be available, so here they are.
Where did I find this stuff ?
A combination of gathering bits of informations here and there, and the ability to think like an Arri R&D guy I guess (they always seem to make the most logical choices in sensor architecture).
CLICK and enjoy for zoomable chart.
#2 Richard Boddington
Richard Boddington
  • 5588 posts
Posted 06 March 2016 - 05:37 PM
Well I bought one, & I am certainly not rich.
R,
  • 1
#3 Phil Rhodes
  • 12407 posts
Posted 06 March 2016 - 05:46 PM
Errr.
#4 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 06 March 2016 - 06:01 PM
By the way if someone finds something that is or might be inaccurate, please tell me and I'll make an update.
Why do you think Arri doesn't share more that kind of infos ?
I think either they think we don't care about the in-depth stuff, or because it makes EI 800 looks bad.
They have this popular "dynamic range" image where we see how you get +5/-9 stops at 200, +7/-7 at 800 etc etc.
This is sort of true, but they forget to mention that every stop isn't created equal, in terms of how many values each has going for him.
A highlight stop might have hundreds of values for it (arriraw), where a low-light stop ony has a couple.
Out of curiosity, I tried to see at what ISO would a middle gray have as many values below and above him : it's ISO 64.
And in terms of stops, it depends where you decided that the dynamic range ends.
The Arriraw has a high-contrast part of the curve that is 8 stops long so if you want high contrast low lights in your file, you'd go for ISO 64 or 80 with a +4/-4 middle gray.
By the way if Art Adams passes by on the topic : Thank you, I learned a lot with your Alexa articles back in the day, and I hope the stuff I shared will be useful to you as well.
Edited by Tom Yanowitz, 06 March 2016 - 06:11 PM.
#5 Phil Rhodes
  • 12407 posts
Posted 06 March 2016 - 06:08 PM
This does remind me of some of the stuff that's been tried by the Magic Lantern people on things like the 5D. It was discovered that there are two readout amplifiers on the sensor of that camera, and that with a bit of trickery they could be set to different gains. These two amplifiers read out alternate lines, so that the net result is alternate lines of the image with different exposures.
Some work was done on this with the idea of interpolating the alternate pairs of lines out, so that it would approximate the Alexa dual-gain approach, but between the difficulties of the interpolation and the preexisting issues with the 5D Mk. II, it wasn't that successful. That's not really the point, though: what all of this implies is that the limits on at least some modern sensors aren't actually full well capacity, they're amplifier dynamic range and bandwidth.
#6 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 06 March 2016 - 06:31 PM
(you mean that the 5D has this with odd and even lines instead of for each pixel ?)
Well, Full Well Capacity is still more important than these electrical trickeries I think, as it influences both sensitivity and dynamic range.
#7 Phil Rhodes
  • 12407 posts
Posted 06 March 2016 - 06:44 PM
Yes, but it doesn't matter if you don't have amplifiers with enough bandwidth and dynamic range (simultanously, of course) to offload that data with adequate noise performance.
The 5D experiments suggest that, at least at the level of a (when new) £2k DSLR, compromises are being made.
#8 David Mullen ASC
  • 20471 posts
Posted 06 March 2016 - 07:02 PM
The trouble with low ISO ratings on the Alexa is that the loss of extended overexposure detail when combined with the hyper clean image tends to make everything feel more digital, and one reason people like shooting with the Alexa is how much Log-C at 800 ISO is similar to a Cineon log scan of film, even if it means a little bit of noise (and it's still less noise than 500 ISO film stock anyway.)
#9 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 06 March 2016 - 07:30 PM
Sure there are reasons both for and against working at ISO 100 or 800 or 1600.
What I'm suggesting is this :
- be aware that by working at ISO 800 you essentially are placing you midtones in the tow of the arriraw curve.
If you don't view it as dark on a monitor, it's because it's pushed by a couple of stops by the "LogC LUT"
- the lower the ISO you work at, the cleanest and highest contrast the image you'll get.
Why working at a higher ISO ?
- you want low-contrast shadows and noise.
- you don't have enough light available and you are at a wide aperture already.
- deep focus is more important than noise and IQ
- you have some extreme highlights in the frame (practicals, lamp shades you want detailed) AND they are the keylight as well so you can't lower their output. (hello Birdman)
(so highlights to mid gray contrast ratio is above 5.5 stops)
(Actually does any knows the contrast ratio between a bright white cloud and a backlit actor's face ?)
So essentially it works exactly the same as when you choose your own ISO/EI with a given film stock.
So overall I'm more for the dynamic use of ISO than the static use.
Cause if for example your actor's face is one of the brightest area of the shot and you're working at ISO 800, the amount of info you'll lose uselessly is crazy.
You will record the whole contrast on a lot less gray values than you'd otherwise have with a lower ISO.
(By the way every time I talk about working at a given ISO, I'm implying setting the f-stop to what the light meter with that ISO tells you too, not the camera's ISO settings, which doesn't do anything to the actual file, just switches monitoring LUTs if you record raw)
Actually ideally you can forget about working with ISO all together and use the ETTR technique but that's an other story.
Edited by Tom Yanowitz, 06 March 2016 - 07:41 PM.
#10 Richard Boddington
Richard Boddington
  • 5588 posts
Posted 06 March 2016 - 07:41 PM
I will say this about the Alexa, its low light shooting capability is superb!  What I was able to do on both Against The Wild films with fire light only was astounding.  And not even a hint of noise in the picture.  If I had tried the same thing with 35mm I would of needed extra light and I know I would of been applying lots of noise reduction in post.  Even using the very best 500ASA from Kodak or Fuji.
Reliability is another factor.....hundreds of stories out there about REDS overheating and dying on set, endless stories.  Not so the Alexa.  On two wilderness shoots, one in Canada and one in Africa, that camera didn't even utter a peep.  It was flawless everyday all day.
Its a serious piece of gear and was well thought out by a company that knows cameras.  If you are in the market, I can recommend the Alexa.
R,
#11 David Mullen ASC
  • 20471 posts
Posted 06 March 2016 - 07:51 PM
Tom, you're thinking like an engineer -- what matters is how it looks on the big screen, and you can't tell me that all these Alexa movies shot at 800 ISO by Roger Deakins and Emmanuel Lubezki look bad because they are "losing too much information".
Also, consistency of exposure and noise within every shot in a sequence matters in narrative fiction, whether or not you are placing information in the optimal part of the curve. You don't expose shots in a scene like you would in still photography where you optimize the exposure and ISO setting for that single image.
  • 1
#12 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 06 March 2016 - 08:04 PM
I am actually convinced they wouldn't keep shooting everything at a high ISO if they knew all that.
It's not about how bad Chivo and Deakins images look at high ISO (they do look great), it's about how different (better or worse) they'd be if they were using ISO dynamically.
Their images might be noticeably or un-noticeably better, but at least equal and never worse.
Lubezki would be the one benefiting the most from it because of his extensive work in post for roto work and power windows. Most of his shots are heavily graded.
And he said they took the Alexa over film cameras for The Revenant because they wanted the least possible noise.
For Birdman they might have often fallen in the "no enough light output" reason for high (1280) ISO.
The most curious thing is : most DPs knew about all this in film days (like the film stock says its 500 but I'm going to work at 250 for deeper shadows and less grain for example)
Some other manufacturers (like Red and Blackmagic) are talking about how you shouldn't underexpose the sensor, but Arri doesn't, either by fear of DPs screwing up and ranting about their clipped footage, or to keep the idea that they are natively ISO 800.
Edited by Tom Yanowitz, 06 March 2016 - 08:12 PM.
#13 David Mullen ASC
  • 20471 posts
Posted 06 March 2016 - 08:16 PM
Sure but they were relying on film's extended overexposure capability when they did that and some were doing it in order to get better blacks due to higher printer lights, plus grain at 500 ISO is higher than the noise of the Alexa at 800 ISO so there is less desire or need to overexpose just to reduce noise. Plus you are assuming that getting the cleanest signal possible is always a priority over extended detail in bright areas. You are also making the false assumption that Deakins, Lubezki, and their DIT's don't already know these issues. And finally, if you have a style that incorporates a lot of available light then you are not going to start out picking a low ISO setting and lighting from there.
  • 1
#14 David Mullen ASC
  • 20471 posts
Posted 06 March 2016 - 08:46 PM
Blackmagic and Red cameras do have more noise problems that crop up due to underexposure, hence their warnings. The Red camera in particular has smaller photosites in order to achieve higher pixel counts so it is not surprising that it is a bit less sensitive.
None of this is new, Tom -- most of us understand the trade-offs between noise and clipping, etc. I understand why Art Adams rates the Alexa at 400 ISO and I've shot plenty of Alexa footage over the years at different ISO's to know how it will look. But this isn't a technical exercise, it isn't a science experiment, we are creating artistic images and one person's image priorities are not another's. If some cinematographer likes what he is getting at 800 ISO, then more power to him, I'm not going to judge anymore than when Harris Savides would underexpose a movie by three stops.
#15 Stuart Brereton
Stuart Brereton
  • 3491 posts
Posted 06 March 2016 - 11:49 PM
I'd agree with David. I shoot with Alexa all the time, and I use 800 ISO when I have highlights I need to control, and at 400 ISO otherwise. 200 ISO and lower just doesn't look as good, regardless of whether it is technically 'better'.
This isn't some new camera that needs a critique, it's an industry standard that just about everyone is very happy with.
#16 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 07 March 2016 - 01:01 AM
And is there any way we can get this chart to fit on the page, next time?  Interested thread, but hell to scroll through.
#17 Tom Yanowitz
Tom Yanowitz
  • 73 posts
  • Paris
Posted 07 March 2016 - 04:37 AM
Sorry Bill, doesn't you browser automatically fit it to the width of your screen ?
Let me re-post a crop of the chart with the most important graphic
I actually don't care that much about what ISO this or that DP uses, as long as they understand the ins and out, and that each ISO has clearly defined advantages.
Just don't call 800 the "base ISO" unless you're a marketing guy at Arri, there's no "base ISO" as long as the people at ISO don't make a norm for raw capture.
You seem to be very afraid of white clipping, as everyone should, but black clipping is actually the more common problem isn't it. With footage having no details whatsoever in the shadows.
It's a problem we see over and over.
An other huge reason for overly underexposed footage (I'm talking to the point where the DIT or DP are fired once people see the dailies) is trusting the monitor for exposure.
And don't get me started on underexposing the raw footage to add noise. That's just nostalgia. If people are so fond of film grain, they could try and experiment with different types of noise in post instead of degrading in capture.
Wanting to be an "artist of light and darkness" shouldn't make one skip the nitty gritty about how digital cameras work (like, for example, that half of a sensor's values are dedicated to the last stop of highlights before clipping).
You guys trust your eye way too much. I did some experiment showing footage at various ISO, but lying about which was which and guess what, what people want to see based on their limited knowledge of the camera takes over what they actually see.
So please tell me in what way the Alexa looks worse at 200.
Edited by Tom Yanowitz, 07 March 2016 - 04:46 AM.
#18 Phil Rhodes
  • 12407 posts
Posted 07 March 2016 - 04:50 AM
This is of course completely true.
The effective sensitivity of digital (and indeed photochemical, to some extent) cameras is based on a compromise between dynamic range and noise and is thus a matter of opinion.
What's interesting about the Alexa approach is that it emphasies that simply recording the light on the surface of the sensor is one thing; offloading it elsewhere is another, and the best current designs need to be careful about both.
  • 1
#19 Carl Looper
Carl Looper
  • 1431 posts
  • Digital Image Technician
  • Melbourne, Australia
Posted 07 March 2016 - 06:14 AM
The best way to obtain film grain is to shoot film.
The resulting image is completely different from adding noise in post, or otherwise exploiting the noise floor of digital sensors.
Noise is not degradation. Finite bit depth is degradation and one which is physically alleviated by adding noise in advance of quantisation.
This is not nostalgia unless a technically better signal is nostalgia.
But what you are otherwise suggesting is correct.
However I wouldn't hold this against cinematographers. They are trying to use digital technology that's framed in terms that don't actually belong to what digital technology is actually doing.
It's marketed as magic, and so cinematographers will treat it like such. As magic. After all it's supposed to be ultra convenient in that way, ie. where you don't need to use one's slide ruler.
Where you only need your creative eye/brain switched on.
In reality, of course, one can squeeze a lot more out of anything if one does use one's technical brain, or otherwise have an assistant (and corresponding post operator) handle that side of things.
C
Edited by Carl Looper, 07 March 2016 - 06:21 AM.
#20 Robin R Probyn
Robin R Probyn
  • 2620 posts
  • Tokyo
Posted 07 March 2016 - 07:40 AM
"I actually don't care that much about what ISO this or that DP uses, as long as they understand the ins and out, and that each ISO has clearly defined advantages."
"Wanting to be an "artist of light and darkness" shouldn't make one skip the nitty gritty about how digital cameras work (like, for example, that half of a sensor's values are dedicated to the last stop of highlights before clipping)."
​Do you not think this comes over as a bit pompous though Tom..  from your Id pic you seem to be a youngish guy.. where do you get the idea that the average DP doesn't know about shifting the grey level .. let alone Deakins/Chivo et el..   is there something in the water students drink these days :)..
Also tagged with one or more of these keywords: arri, alexa, sensor, iso, dynamic range, ei, digital camera
