Power solution for smallhd 500 and 700 series monitors!
#1 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 12 March 2016 - 10:02 AM
Hello everybody!
Just wanters to share this project Ive had Im my head for a while but finally came around doing today. I've installed a 2-pin lemo on what used to be a Zacuto D-tap -> LP-E6 battery adapter to be able to use standard lemo-lemo or lemo-d-tap cables when using the monitor on Alexa or Red.
I used the information on this page to get the polarity right:
https://mediablackou...pin-Lemo-cable-
The black wire goes on the red-dot input.
#2 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 12 March 2016 - 10:04 AM
Here are some more pictures
#3 Phil Rhodes
  • 12407 posts
Posted 12 March 2016 - 11:34 AM
Handy. I assume it'll stand the higher voltage OK?
Atomos make similar things for their recorder-monitors, though they're usually D-tap input. They're also emblazoned prominently with an "Atomos devices only" legend, to minimise horrible, smoke-releasing mistakes.
#4 Haris Mlivic
Haris Mlivic
  • 55 posts
  • Stockholm
Posted 12 March 2016 - 12:04 PM
Yeah, the regulator from the original adapter is still in there. Dont know about 24v though.. Yeah there are a lot of adapters with the cable attached, but I couldnt find one with inputs. The plan is to just habe it in there at all times, as if there was an power input on the monitor (that it should have had to begin with)
#5 Phil Rhodes
  • 12407 posts
Posted 12 March 2016 - 01:01 PM
In case anyone else needs to do that, in situations like these things like this can be very useful.
