How did they do this awesome shimmer light? kpop video
shimmer light k-pop
23 replies to this topic
#1 Roger Alexander
Roger Alexander
  • 46 posts
  • Atlanta
Posted 14 March 2016 - 12:31 AM
K-pop videos are pretty impressive. In this video, theres a scene in a studio with gravel ground, black background, dance scene with the girls, and they have this shimmering top light and I can't figure out how they did this. It's almost like they shined the light through water? or maybe bouncing the light from water to give the shimmer. But how do you do that above the dancers? Maybe there's multiple lights above them moving fast? or maybe the lights are on some DMX system for the effect? Sometimes the camera goes out really wide, so the lights have to be pretty high (unless they were painted out). Anybody know how they did this? It's pretty awesome.
Start watching at 00:19
https://www.youtube....h?v=CNLELuDjHNA
 I couldn't find a behind the scenes.
#2 aapo lettinen
aapo lettinen
  • 1219 posts
  • Finland
Posted 14 March 2016 - 01:30 AM
the light effect has regular pattern so it is definitely dmx fixtures. I'm not a expert of stage lighting but multiple gobos could do the job I think. It's lots of rotating light patterns moving around
#3 aapo lettinen
aapo lettinen
  • 1219 posts
  • Finland
Posted 14 March 2016 - 01:34 AM
there is all kinds of cool stuff in stage lighting :)  here is an example of the gobo filtering https://www.youtube....h?v=sQ6VP8zL8Ac
#4 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 14 March 2016 - 06:02 AM
 DMX has noting to do with the lighting effect, dmx is a control signal.  It could be as simple as as two gobos in a gobo rotator installed on a leko.
#5 Phil Rhodes
  • 12407 posts
Posted 14 March 2016 - 06:03 AM
I just yesterday delivered some stuff to be played back on Robe MiniMe lights, which are essentially video projectors mounted on a pan-and-tilt mount. Since it's static, the effect you mention might also be done simply using a video projector.
Or, you know, just a big light, a tray of water, and a couple of mirrors. Dafter things have been done.
I'd also almost believe it was more conventional lighting with some sort of breakup optical effect in it. Some intelligent lights have gobo wheels and into those gobo wheels you can mount various bits of distorted glassware to create effects akin to that. But I suspect it's a bit too complex for that.
#6 Freya Black
Freya Black
  • 4166 posts
Posted 14 March 2016 - 08:41 AM
That video has cheered me up a bit. Light fixture with double gobo roatator built in!
A shame the fancy glass gobo's are uber money.
Freya
#7 Phil Rhodes
  • 12407 posts
Posted 14 March 2016 - 09:37 AM
Yes, although to be fair you can just go down to your local glass place and see what bits of wibbly glass they have in the offcuts bin.
Yes, yes, I know, this won't work because it isn't expensive enough, but once you've tried it in private to ensure it won't crack or melt, you're fine.
#8 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 14 March 2016 - 02:33 PM
Roger,
Look at renting equipment from a DJ company or live event production company.  American DJ (adj.com) makes LED lighting equipment with this effect built in.  I'm sure if you contact them they can recommend what you need to rent.  Generally it's pretty cheap.
Being in Atlanta I imagine you should have plenty of live event and club DJ vendors to rent from.
S.
#9 Freya Black
Freya Black
  • 4166 posts
Posted 15 March 2016 - 04:21 AM
Well don't forget it needs to be the right size and shape to fit in the gobo rotator and cutting glass like that can be difficult.
I was actually thinking that if you could find dichronic glass of the right diameter then you might be able to etch the patterns in with a dremal tool. It's more difficult when it's the mixed colour glass of course.
Edited by Freya Black, 15 March 2016 - 04:21 AM.
#10 Phil Rhodes
  • 12407 posts
Posted 15 March 2016 - 05:35 AM
You can also just dribble superglue onto an optical flat, although that doesn't deal completely perfectly with heat. Or, you can crush up some pieces of glass and put them on the flat, and put it in a kiln. Or, melt and distort a piece of glass with a gas flame. Many options!
#11 JD Hartman
JD Hartman
  • 1809 posts
Posted 15 March 2016 - 06:03 AM
Cripes is this a music video shoot or an arts and crafts project?  It's a gobo rotator, lots of possibilities, Rosco's Youtube channel: https://www.youtube....IhMWsvNwbhalByA
You don't make it, you just rent it.
#12 Phil Rhodes
  • 12407 posts
Posted 15 March 2016 - 09:07 AM
PRODUCER
We need a rippling water effect!
PHIL
Fine. We'll need a Rosco gobo projector.
PRODUCER
How much will that cost?
PHIL
About £100.
PRODUCER
...no.
PHIL
Well, I guess we'll have to go without, then.
PRODUCER
My friend said he could do it for £3.
PHIL
I'll be in the shed.
#13 JD Hartman
JD Hartman
  • 1809 posts
Posted 15 March 2016 - 11:26 AM
100 pounds to rent?  Somehow I doubt it.  Tell me what kind of glass shop will have the type of glass that won't grenade in the heat of the gobo slot?     What will it cost to replace the Leko and lens barrel when it does?
#14 Phil Rhodes
  • 12407 posts
Posted 15 March 2016 - 12:19 PM
It doesn't matter what it costs to rent, the answer is no. The answer is always no. The answer to a stand is no. We've had this conversation before.
You live on Mars. I shall draw some antennae on your profile shot!
#15 aapo lettinen
aapo lettinen
  • 1219 posts
  • Finland
Posted 15 March 2016 - 01:04 PM
good quality borosilicate glass. should not be that difficult to obtain. laboratory glassware could also do if you can find it in usable shape, for example borosilicate petri dishes etc.
there is also lots of custom lab glassware companies and optical companies which could do anything from the boro glass, for example round discs which would be similar size to cd:s , etc
#16 Roger Alexander
Roger Alexander
  • 46 posts
  • Atlanta
Posted 15 March 2016 - 01:27 PM
thanks alot guys! This helped alot. I'm going to start looking for places to rent something like this. Awesome feedback on this forum! I feel like I will be visiting here much more frequently!
#17 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 01 April 2016 - 05:10 PM
Hey,
There is a fixture which I do hire when I light for the stage called a water effect. Yes we have very easy names in India. It rents for like 20 USD for 2 shifts
Damn that song is catchy
Edited by Vivek Venkatraman, 01 April 2016 - 05:10 PM.
#18 Alexandros Angelopoulos Apostolos
  • 471 posts
  • Athens
Posted 06 June 2016 - 12:24 PM
I have no idea how I bumped onto this, but it kind of reminded me of the K-pop video above: how did they achieve the effect appearing at 1:43 and what creates those light beams (there’s a better word for it, but I can’t remember right now) for the scenes at the cinema:
The video looks like a copy of Mariah Carey’s Heartbreaker.
#19 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 06 June 2016 - 03:34 PM
Guessing you are referring to the Anamorphic lens flares which look like they were added in post using a flare plugin since nothing else looks like it was actually shot anamorphic.
#20 Alexandros Angelopoulos Apostolos
  • 471 posts
  • Athens
Posted 06 June 2016 - 03:47 PM
Well, I’m sure it wasn’t anamorphic. :D It’s around 1:00.
Any guess about the 1:43 light?
