Anyone seen umbrellas that fold out with no handle?
24 replies to this topic
#1 andrew ward
andrew ward
  • 269 posts
Posted 21 March 2016 - 12:21 AM
Ive seen a new zealand one and Modern make one but its a bit poop and expensive.
Its a large umbrella but the handle is out to the side. So basically you can have it shading the dolly and the stand can be on the side. Or covering a lamp from behind.
Its so you dont have the annoyance of the largw handle directly under it which means the stand its in will be in the way.
Anyone knows where they come from?
Not sure if its lighting or grip.
  • 1
#2 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 10:35 AM
Photek Sunbuster?
http://www.bhphotovi...s_84_White.html
#3 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 10:36 AM
It is basically a patio umbrella with a Poly silk skin.
If you just need shade then any patio umbrella with a joint to angle the top will work.
Edited by Edward Lawrence Conley III, 21 March 2016 - 10:37 AM.
#4 andrew ward
andrew ward
  • 269 posts
Posted 21 March 2016 - 02:02 PM
A patio umbrella needs a huge cantilever.
But yes, its a smaller version of that.
Like I said, this umbrella is more useful than a standard umbrella with tilt head.
#5 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 04:28 PM
A regular type rain umbrella?
#6 andrew ward
andrew ward
  • 269 posts
Posted 21 March 2016 - 05:40 PM
Its for sunshade.
My example of shadowing a DP on a dolly without the umbrella having to be on the track.
It folds flater than a normal umbrella, so its almost like putting up a 4by except it folds up. And arms a bit further away from stand.
Theyre awesome. If I could just find who makes them!
Probably a kiwi grip.
Moderns version is shitty and EXPENSIVE.
#7 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 07:27 PM
Do you have a link for Moderns?
#8 andrew ward
andrew ward
  • 269 posts
Posted 21 March 2016 - 07:35 PM
No I think it was a custom order
I know a gaffer in Sydney who has one of the ones I want, i think from nz. And another gaffer here just got two from modern to put over 18k arrimaxs.
I cant find it on google or find an image or anything. I probably just need to know a name and it will come up. Searches just bring up those massive cantilever umbrellas.
#9 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 07:44 PM
What is Modern?
Modern Grip?
#10 andrew ward
andrew ward
  • 269 posts
Posted 21 March 2016 - 07:49 PM
Correct.
#11 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 21 March 2016 - 07:54 PM
hmm.
Well time for a beer here and Modern is closed so can't call them now and they have a crappy online catalog.
#12 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 22 March 2016 - 11:13 AM
Ah Ha!
It is a Tractor Umbrella/ Canopy
http://www.ebay.com/...p-/230819960407
#13 andrew ward
andrew ward
  • 269 posts
Posted 22 March 2016 - 05:28 PM
YES!!!!
F8king GOOD JOB!
How the h$ll did you find that!
THANK YOU!!!!
#14 David Erlichman
David Erlichman
  • 49 posts
  • Grip
  • Toronto, Ontario, Canada
Posted 22 March 2016 - 09:24 PM
Modern doesn't make / convert the umbrella anymore (at last check). You can find the manufacturer and just swap their spigot for a JR spud.
Edited by David Erlichman, 22 March 2016 - 09:24 PM.
#15 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 23 March 2016 - 10:54 AM
I called Modern.
they still make the Tractor Umbrella with spud but they make them to order now. $300.00  :0  (The $250.00 price was only once)
If you go their website  click on the Tab "Current, Modern Mondays, go towards the bottom on the right, "Follow Modern on Instagram" scroll down, click on "Load more"
https://www.instagra...tudioEquipment/
#16 andrew ward
andrew ward
  • 269 posts
Posted 25 March 2016 - 09:24 PM
Coolness.
The original one I saw was even better than this "tractor umbrella" style as it was almost flat when folded out, and the holder went straight out, not out then bends back. So it went further from stand.
But this'll do!
Thanking!!
#17 Kim Alister Worthington
  • 9 posts
  • Grip
  • Prague
Posted 17 April 2016 - 12:34 PM
Hi.... I spent a lot of time a few years ago sorting out brollies in my truck, so I have a certain level of knowledge about them, trivial as that may sound. The kiwi umbrella you mention was known as the 'Ben Bell', after its designer and manufacturer. Sadly he left the industry some years ago but now makes great worm farm/ compost bins! The Ben Bells haven't been manufactured in years, but a few antipodean gaffers and grips have kept a supply maintained. I have one left myself...
The modern version is shite. Then again I'm not a great fan of modern studio equipment anyway...
The only other version of the offset umbrella I know of is ARRI rental Europe, who do exact copies of the Ben Bell, only not quite as high quality. The main advantage of these brollies in my opinion, is that if you face the knuckle into the wind, they are rather resistant to strong gusts. The weak point is the ball joint knuckle though, and if the kip lever is not doing its job properly then they can get out of control very quickly.
I have stopped using the offset brollies myself, as they do take a little longer to set up. And while the offset junior pin is great, my dolly grip was moaning to me about not getting any shelter himself. Which got me thinking... and in the end I thought he probably had a point, so I found industrial quality umbrellas marketed for welding railways. They are fantastic. 2.5 m (8ft) diameter, easily inserted a junior pin in the stalk, quick to erect, full grid /showercloth type fabric, and at the end of the day, provide as much coverage as the Ben Bell on one side 1.2m (4ft), and coverage on the other side of the stalk for the dolly grip, focus puller, lens cases etc. I mount them in Matthews slider stands with a couple of shot-bags and they're reliable, fast, and very good at keeping the weather off the camera and crew. Hope I don't sound overly pedantic, but I really went through this process thoroughly so I sympathise!!,
#18 andrew ward
andrew ward
  • 269 posts
Posted 17 April 2016 - 03:59 PM
Aha!
I knew someone would know.
Thats interesting.
I dony get how the "jointers umbrella" does the job. Thats just a standard grip umbrella. Or is there one which is huge?
#19 Kim Alister Worthington
  • 9 posts
  • Grip
  • Prague
Posted 18 April 2016 - 05:06 AM
I guess its just a standard grip umbrella... but the ones I brought are very well made and tough. And i was able to insert and rivet a junior pin in the bottom with no machining. This is the link http://www.sheerspee...68ft-5105-p.asp
Like I say, I have the original Ben Bell in my truck (it's 20 years old now!), and I have access to Arri Rentals copies, but none of the grips here like using them as they do take a bit more work to put up and take down.
#20 kris wallis
kris wallis
  • 6 posts
  • Grip
  • Sydney
Posted 04 September 2016 - 02:13 AM
It seems there is a bit of an umbrella crisis, the manufacturer in Australia has stopped manufacturing locally and now only make junky ones in bright colors as opposed to the high quality black ones that were industry standard for decades over here, I'm disappointed to hear that the modern variant is crap as I was about to order, they owe me for their rubbish attempt at filling my previous order. Can you buy the arri ones I've seen online ?
Opal
Opal
