Calculating data storage
data storage harddrives space
#1 Marcus Allemann
Marcus Allemann
  • 26 posts
  • 2nd Assistant Camera
  • Berlin
Posted 24 March 2016 - 02:10 PM
Heya team,
I'm about to go in on a job as a Data Wrangler and it's been long enough for me in between wrangling to lose touch with a reasonable estimate of calculating ROUGHLY what sizes of storage space I should be looking at considering the following:
- TV series (53 shooting days)
- 1 camera shoot
- Alexa shooting ProRes 4444 2k on SxS cards (64gb and 32gb) (standard drama, nothing particularly excessive frame rate wise)
I'm fighting to get a more exact idea but no one can get back to me with a shooting ratio, script length or any other idea aside from what I know above.
SO, I'd be keen to hear if there are any estimates out there from people with a better memory/ more experience than me.
otherwise, would appreciate if anyone could point me in the right direction of some resources that have a method for working out a vague calculation based on those bare essentials. Is there a rule of thumb?
cheers
#2 Phil Rhodes
  • 12369 posts
Posted 24 March 2016 - 03:31 PM
You need a rough idea of what they expect to shoot, or you're nowhere. You could guess something, but you'd be on very thin ice unless you built in a truly massive safety factor, and even then you could find yourself working under Mr Seven Hours a Day and end up in serious trouble.
ProRes 4444 runs fractionally under 300Mbps, or a bit more than 130GB an hour. Beyond that, it's just multiplication. With a single LTO deck, assuming reasonable supporting gear, you could theoretically keep up with several hours a day, but you need some wiggle room.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 24 March 2016 - 07:39 PM
Use the AJA Data Calculator app: https://www.aja.com/en/family/software
It's the fourth item down from the top. I don't know how you can possibly be expected to estimate the daily byte count without a daily page count or expected shooting ratio.
Maybe the production company has produced a comparable show recently that you can use as a template?
#4 Marcus Allemann
Marcus Allemann
  • 26 posts
  • Berlin
Posted 25 March 2016 - 04:08 AM
Assuming I can get my hands on scripts, isn't there a formula used to calculate the number of pages into an amount of material?
I seem to remember something from my loader days on film like that. Then as long as I can hypothesise a shooting ratio it would give me something in the ballpark.
#5 Brian Drysdale
  • 5331 posts
Posted 25 March 2016 - 05:09 AM
Usually a script roughly works out at around a minute per page. However, on TV series, the scripts can be over length, script editors claim 5%, but it can be 10% to 15% over length according a film editor friend working on UK television dramas..
#6 Phil Rhodes
  • 12369 posts
Posted 25 March 2016 - 05:12 AM
Sort of, maybe, but I wouldn't rely on it.
Some people shoot a lot more coverage than others.
It's one of those things where everyone seems to think their approach is standard.
#7 Mark Kenfield
Mark Kenfield
  • 1224 posts
Posted 25 March 2016 - 09:00 AM
Well approximate shooting ratios are always going to be a more accurate way to plot out your data needs. However, without that, I'd work off the fact that on a single camera narrative shoot, when the cast and crew are on fire, and you're smashing out scenes - you might just get two hours of material recorded on a single day. So I'd plan around that two hours/day figure lacking better info.
Odds are you'll be over-catered for with that much space on most days, but better safe than sorry,
Cheers,
Mark
