Common issues with SR3
sr3 sriii arri super 16mm s16mm super 16
#1 Drew Bienemann
Drew Bienemann
  • 42 posts
Posted 24 March 2016 - 07:12 PM
Hey,
I found someone with a bunch of old replacement and repair parts for SR3's. i just bought mine, so it's currently in top shape, but I was wondering what some common issue were after a bunch of use. if possible I'd love to buy some parts now to have on standby before they disappear forever.
I know that the SR2's used to have circuit issues, but im not sure if that's a common SR3 issue.
Motor? Registration pin?
#2 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 25 March 2016 - 11:45 AM
I'd have a spare gate because it's a very common wear item on that camera. I'd also buy a few backplates for the magazines, to insure they don't fail on you and need replacing up the road. Obviously a spare movement would be nice, but it's less of a wear item then the gate and pressure plate.
#3 Kenny N Suleimanagich
  • 902 posts
Posted 25 March 2016 - 11:48 AM
I'd add sprockets and mag clutch parts to that
#4 Dom Jaeger
Dom Jaeger
  • 1788 posts
  • Melbourne, Australia
Posted 25 March 2016 - 05:48 PM
SR3s were built like tanks, unless mistreated you had to run seriously huge amounts of film through them before wear became an issue with most parts of the camera. We're talking TV series shooting for hours a day over months, repeated for years. Not something an owner/ operator or Indy filmmaker generally has to worry about.
In my experience looking after a rental house inventory I never had to replace an SR3 gate or the pressure plates in a mag. SR2 gates sometimes, usually just the side rails though. But SR3 gates just didn't wear, they had sprung sapphire guides and a very hard chromed surface. If you cleaned one with something metal maybe you'd scratch it..
I also wouldn't worry too much about movement parts if the camera is steady and quiet, it will take thousands and thousands of feet before wear becomes an issue, unless the movement gets contaminated. Maybe a spare claw if you're concerned about parts availability down the road, though I suspect qualified technicians who can diagnose wear and properly replace movement parts will run out sooner than the parts themselves.
Definitely the mag clutch can wear, as Kenny mentions, and the mag drive gear can get damaged teeth (get the flexible semi-opaque ones not the hard plastic ones). Usually it was little things like the mag footage counter cover panel getting cracked, or the rubber inserts on the mag doors tearing. Mag door latches. Running light bulbs and housings. Memory batteries. Pico fuses. Eyepiece optics might get scratched, viewfinder Pechan prisms sometimes yellowed, RS sockets got burnt when someone plugged their incorrectly wired power cable in. Generally it was damage rather than wear, which can be anything really. Bits that stick out can get hit. The mirror sometimes got scratched when someone stacked rear filters on a lens.
I would actually recommend saving your money buying parts that may never need replacing, and spending it instead on regular maintenance with a tech who really knows SR3s. Once every few years, or if the camera gets contaminated in a dusty or corrosive environment. Wear becomes a problem when a camera doesn't get regular maintenance (just like a motor car really).
  • 2
#5 Drew Bienemann
Drew Bienemann
  • 42 posts
Posted 28 June 2016 - 10:19 AM
man, that's great, everyone! thank you!
Also tagged with one or more of these keywords: sr3, sriii, arri, super 16mm, s16mm, super 16
