Converting video-assist to HD
#1 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 25 March 2016 - 10:48 AM
Hi everyone,
I have already been schooled on this subject by the community that speaks for my monitor company so yes, I already know my stupidity.
I bought the PIX-E5 to use with my schools cameras, a mixture of Sonys, one Alexa, and one RED Dragon, and of course out film cameras. Now it turns out two things that I should have looked up.
My monitor/recorder only supports HD resolutions, and it has to be a digital one. So my monitor is pretty useless. But I started to think if there is a solution to this. I had people telling me that the Decimator MD-HX might a solution to make this work. Problem is, I was planning using this in the field so I need a battery solution.
So to make it simple.
A, does the Decimator MD-HX have the capability to make a NTSC composite signal through BNC, to a 720 BNC?
Link:
http://www.amazon.co...n/dp/B00QPRGGCS
B, Is there a way to run this on an external battery (but not a D-tap since the Arri SR-3 does not have that)?
/C
#2 Kalle Folke
Kalle Folke
  • 79 posts
  • Stockholm
Posted 25 March 2016 - 04:52 PM
Hi!
I've just been researching for a similar solution. From what I understand the Decimator product you'd need is: http://decimator.com...DADC/SDADC.html but it's out of production.
I got a Aja V2Digital: https://www.aja.com/...rters/v2digital
For me it's works to convert the analog signal from a Arri 416 to a Sound Devices Pix240 monitor/recorder. Blackmagic makes a analog-digital converter also. It's cheaper but my rental house recommended me to avoid it and I generally don't trust Blackmagics products so I choose the Aja.
I can power the converter with d-tap but I'm waiting for a custom cable to let me power it from the 416 "mini-monitor" port (12v). If you don't have the option of getting power from the camera (it should be possible) I think it would not be hard to make a adapter to power it from small "dv-cam batteries". The power connector on the converter is some strange type so you'd need to get that from Aja I think.
I choose to get the adapter since I want to record the video tap with the cameras timecode burnt in so I can sync sound from the sound recorder manually when not using a slate. If you just want a monitor it would be much cheaper to get a used SD monitor to use with film cameras with analog video taps. I got a old Transvideo monitor for around 80€ and it also does the job.
#3 Kalle Folke
Kalle Folke
  • 79 posts
  • Stockholm
Posted 25 March 2016 - 05:00 PM
Just did some more thinking and maybe you'd still have a problem is the Pix-e5 only works with 720p signals… The Pix 240 seems to have much more options for input signals, including PAL and NTSC.
I can try with a SmallHD 502 to see if it works with the converter, but I'll not have access to the camera until next week.
Good luck!
#4 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 26 March 2016 - 07:03 PM
Good luck!
I would love for you to check on this to get an actual real answer.
That said I read the manual for the decimator (here http://decimator.com...ANUAL_FV1.3.pdf ). And it seems it does accept 480/576 in (so NTSC/PAL), and it DOES upscale to whatever resolution I need (HD)
Hence I do think't it would work.
C
#5 Kalle Folke
Kalle Folke
  • 79 posts
  • Stockholm
Posted 27 March 2016 - 03:57 PM
I hope someone with more technical knowledge can give a better answer but to me it looks like the decimator will work. Only thing I'm not sure about is if it converts a analog signal to a digital signal. Maybe it upscales a digital SD signal but not a analog? If it does convert a analog signal I think my reseller gave me the wrong info and I sure will regret not getting the decimator since it would be handy to also have a SDI-HDMI converter...
I'll get back to you if I have some useful information, please let me know what you find out. Maybe a email to Decimator could give an answer.
Take care!
#6 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 28 March 2016 - 10:50 PM
Take care!
Back to square one.
Hi Carl,
The MD-HX is a digital only device and so can only convert SDI/HDMI to SDI/HDMI, to do the function you require you would need an analogue to SDI/HDMI converter which we currently do not offer.”
#7 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 28 March 2016 - 10:53 PM
Hi!
This seems to be what I am looking for.
https://www.aja.com/...0a-plus#support
C
#8 Alex Alexandrov
Alex Alexandrov
  • 11 posts
Posted 03 June 2017 - 02:42 AM
hi Kalle, I have a question about Aja V2Digital, what cable do you use to connect it to 416 IVS out to V2Digital in?
#9 Kalle Folke
Kalle Folke
  • 79 posts
  • Stockholm
Posted 13 March 2018 - 02:27 PM
Hi Alex,
I'm sorry for the really late reply… unfortunately I forgot what cable I used and I no longer have the camera. Hope you found out anyway! Take care/Kalle
