What am I filming in?
#1 Samuel Smith
Samuel Smith
  • 5 posts
Posted 03 June 2005 - 03:32 PM
Okay, I recently got an HDR-Fx1 and I am confused a bit. When I am in HDV mode am I running at 60fps and 1080i? Wht about when I am in DV mode and then when I film 16:9 in DV mode does the fps or anything else change?
Thanks for any info you have.
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 03 June 2005 - 03:55 PM
<{POST_SNAPBACK}>
30 FPS 1080i (60 fields) . In DV 16x9 or 4x3 only the pixels change shape, the no of pixels recorded to tape remain the same.
Stephen
#3 Samuel Smith
Samuel Smith
  • 5 posts
Posted 03 June 2005 - 04:07 PM
I filmed something in DV widescreen (not HDV) and then I am using FCP4.5 to edit. When I go to import the footage it says unable to locate device 720x480. I go to File>Easy Setup and try using different settings but I can't seem to find the one that I need because it never recogonizes the device. When I go into the Capture and Log window I CAN control my camera, but there is no audio or video coming in. What's going on here? Are my settings wrong, on the camera or FCP?
#4 Phil Rhodes
  • 12296 posts
Posted 03 June 2005 - 05:11 PM
This forum isn't really intended for that kind of question - you're likely to get better answers over on dv.com or creativecow.
Phil
#5 Elhanan Matos
Elhanan Matos
  • 432 posts
  • Digital Image Technician
  • Santa Monica, CA
Posted 04 June 2005 - 12:30 AM
Make sure you have i.link turned on. Go through your IN/OUT SET menu and make sure it's all right. If you follow all the instructions in the manual it should work just fine.
