F stop vs. T stop
f stop t stop aperture exposure lens
13 replies to this topic
#1 Christian Schonberger
  • 189 posts
  • Sound Department
  • Lisbon
Posted 02 April 2016 - 09:55 AM
Hi group,
Well I was always wondering: Why don't lenses provide the F stop which exactly corresponds to the light actually hitting the film emulsion or sensor (not accounting for lens flare and other random factors, just the glass inside the lens)? So in reality: if I get an F stop value from, say, a light meter, I most likely will get it in T stop. Otherwise the "exposure triangle" would make no sense (to me that is). Looks like some lenses are reducing as much as one stop while others perhaps a third of a stop. There is some information for some lenses regarding the actual T-stop, but many don't come with that information - and even with that information: what to do? Now add certain filters and you're into some serious math....
The only thing that remains the same (F stop/T stop) is of course the depth-of-field/focus.
Fully automatic digital cameras with 100% matching lenses (or built-in ones) most likely take all that into account (to varying degrees of success IMHO). But what about using different lenses with no electronics and a 100% manual exposure? With film, once it's in the camera (and you don't have a variable shutter angle) your only way(s) to control exposure is/are lighting, filters and F stop.
Please let me know how you go about the F stop vs. T stop issue and avoid under exposure.
As always: any reply highly appreciated.
Christian
Edited by Christian Schonberger, 02 April 2016 - 09:56 AM.
#2 Mark Dunn
Mark Dunn
  • 2904 posts
Posted 02 April 2016 - 10:23 AM
You use the T-stop. Cine lenses are usually marked in T-stops but it's only really relevant for zooms or complex lenses with a lot of elements. If necessary, you find it out by testing.
Even for a fairly long zoom it's usually only about 1/3 stop.
Edited by Mark Dunn, 02 April 2016 - 10:24 AM.
  • 1
#3 Brian Drysdale
  • 5343 posts
Posted 02 April 2016 - 10:27 AM
You may find they're you're getting ramping of the exposure at the longer focal lengths on zoom lenses. It's unusual to get a one stop difference between f and T stop on modern glass, on old, 1960s zooms it could get into that range.
  • 1
#4 Christian Schonberger
  • 189 posts
  • Sound Department
  • Lisbon
Posted 02 April 2016 - 11:22 AM
Mark and Brian,
Thanks for the information!
Christian
#5 David Mullen ASC
  • 20471 posts
Posted 02 April 2016 - 12:14 PM
A T-stop is an f-stop mark corrected for actual transmission (exposure).  The only reason to use an f-stop mark instead is for depth of field charts because depth of field is still determined by the size of the aperture, not the amount of light reaching the film.
Besides more accurate exposures from T-stops, when you use multiple cameras and set them all to the same T-stop, you are likely to get closer to the same exposures than if the lenses only had f-stop marks.
Now in reality though I've found that even T-stop marks are not completely accurate, something you wouldn't have spotted shooting film but you can see on digital cameras.  For example, shooting on the three lightweight Angenieux zooms, 15-40mm, 28-76mm, and 45-120mm, I've always found that the 45-120mm image was slightly brighter than the other two if they all had the same T-stop.
  • 2
#6 Christian Schonberger
  • 189 posts
  • Sound Department
  • Lisbon
Posted 02 April 2016 - 01:06 PM
Thanks for the information, David. You are very likely referring to focal lengths applied to a 35mm (type) sensor with 50mm being the "mid point" standard. So 15-40 would be a wide angle zoom, then a mid range zoom (around 50mm) and the brighter 45-120mm would be a mid range (standard) to moderate telephoto zoom, correct?
Thanks again,
Christian
Edited by Christian Schonberger, 02 April 2016 - 01:07 PM.
#7 Carl Looper
Carl Looper
  • 1431 posts
  • Digital Image Technician
  • Melbourne, Australia
Posted 03 April 2016 - 05:50 PM
Yes, as David pointed out the f/stop is useful for depth of field calculations. I've been recently writing software for a film out setup in terms of what allowable error range there could be in lens focus before the definition of the result became unacceptable. And for this the f/stop, rather than the t/stop, became the important number - along with the "circle of confusion" number one wanted to use in defining the range of acceptable softness either side of the optimum focus point.
C
  • 1
#8 Christian Schonberger
  • 189 posts
  • Sound Department
  • Lisbon
Posted 03 April 2016 - 08:18 PM
C
Thanks for the information. I always wondered how the depth of field is actually behaving. It is very likely some sort of distorted bell curve with the focus rolling off on both sides (obviously steeper on the near side and shallower on the far side - and the curve widening as the focal point moves farther away). I'm sure there are graphics showing how different lenses behave at different apertures and with different focal points, just like frequency and directional response curves for microphones. Would love to take a look, just to get a basic idea. I'm sure this is very complex taking lens aberrations and lens blur behavior/distortion (the good old bokeh) into account - not to mention what is considered truly acceptable (here come-in sensor pixel resolution, noise and data compression artifacts - and film grain structure and light bouncing artifacts within the emulsion layers in color film).
Cheers,
Christian
Edited by Christian Schonberger, 03 April 2016 - 08:23 PM.
#9 Carl Looper
Carl Looper
  • 1431 posts
Posted 03 April 2016 - 10:58 PM
The f-number is the result of dividing the focal length of the lens by the diameter of the iris. Or reciprocally, the diameter of the iris is the result of dividing the focal length by the f-number.
When we write an f-number (N) in the form: f / N, we're literally representing the diameter of the iris: focal length (f) divided by the f-number (N)
For example, when we write:
f/5.6
we're literally expressing the diameter of the iris. All that remains is to replace f with the focal length of the lens and perform the division.
For example, with a 25mm lens, and an iris setting of f/2.8, the expression f/2.8 literally means: 25mm / 2.8, which means: 8.9mm (the diameter of the iris).
https://en.wikipedia.org/wiki/F-number
Given the diameter we can calculate depth of field:
https://en.wikipedia...he_DOF_formulae
C
Edited by Carl Looper, 03 April 2016 - 11:09 PM.
#10 Christian Schonberger
  • 189 posts
  • Sound Department
  • Lisbon
Posted 04 April 2016 - 02:19 AM
Thanks a lot for the reply. Yep, I knew about the f-stop formula and that it is literally using focal length and aperture (I just couldn't remember what is divided by what). Thanks also a lot for pointing out the article. Excellent images to see how the blur appears gradually when the depth of field is very narrow. I only know extremely narrow depth of field from 150 year old metal plate silver stills photography: the eyes are sharp and the eye lashes are already blurred ;-)
Thanks again,
Christian
Christian
#11 Ryan Fleet
Ryan Fleet
  • 44 posts
  • Editor
  • Buffalo
Posted 28 September 2018 - 02:06 PM
After reading "A T-stop is an f-stop mark corrected for actual transmission (exposure)." -  it would be correct for me to say... When I use my Sekonic L-478D meter to measure the light and it gives me a reading of F5.6, I can set any lens marked with T stops to T5.6 and it will be a more accurate exposure compared to any lens marked with F stops to F5.6?
What I"m really trying to figure out is since my meter gives me an F stop reading will a cine lens marked with T stops be an issue for me or is it as simple as just setting the T stop to the F stop reading?
#12 Adrian Sierkowski
  • 7516 posts
Posted 28 September 2018 - 02:57 PM
The T stop is the "true" stop an your meter will be reading that-- hence setting a "t" stopped lens to 5.6, if your meter tells you to will give you the proper exposure.
In almost all circumstances it makes no difference between T and F stops as most will be within about 1/10th of each other, or so.  It only gets hairy when dealing with zooms and some older lenses.
  • 1
#13 David Mullen ASC
  • 20471 posts
Posted 28 September 2018 - 07:30 PM
An f-stop is a physical thing determined by the size of the lens aperture compared to the focal length of the lens, etc.  A T-stop is just the f-stop mark on the lens moved to be more accurate, exposure-wise, to compensate for light-loss through the lens.  It has been corrected for the true light transmission of the lens, so when your meter gives you an f-stop reading, you'd use the T-stop setting on the lens to accurately set the lens to what the meter is telling you.
  • 1
#14 Dom Jaeger
Dom Jaeger
  • 1928 posts
Posted 28 September 2018 - 10:28 PM
As others have mentioned, the difference between the geometric (f/stop) and transmitted (T stop) aperture setting on modern lenses is often very minimal.
A T2.1 Zeiss CP.2 for example is f/2 which is a difference of less than a sixth of a stop, a common figure for standard prime lenses. Some primes might have quite a few elements and lose a little more light, for example a T1.9 Ultra Prime might be f/1.7, which is closer to a third of a stop, but that tends to be the upper limit for most primes.
Zooms can vary more, particularly older ones. The various iterations of Angenieux's famous 25-250 for example have all had a maximum geometric aperture of f/3.2, but varied from T3.9 in the earliest version from the 60s (a loss of nearly two thirds of a stop), to T3.7 in the 80s and T3.5 in the latest model (closer to a quarter stop loss).
Still photography zooms can often vary in transmission loss (or have unmentioned aperture ramping) through the range, so for example according to the DxO Mark website a Canon f/2.8 24-70 is T2.9 at 24mm but T3.2 at 70mm, a variation of nearly a third of a stop.
As a general rule, primes lose less than a quarter of a stop, modern zooms about a third and older zooms between a third and two thirds of a stop.
In practice, these are often pretty small differences, but for a cinematographer trying to match exposures between lenses (especially in the days before wave-forms or post software) it could be important.
Actually I'd be curious to know how often DPs rely on meters and aperture marks these days, rather than wave forms and monitors. As David mentioned earlier, with modern digital monitoring tools, there can sometimes be visible differences noticeable between lenses set to the same T stop, which could be due to quality control issues, undocumented ramping or variations in transmission through a zoom range, or even coating differences that alter apparent brightness depending on the colour spectrum. I once had a conversation with a particular lens manufacturer's rep who complained that a rival lens company "cheated" with their T stop marks to achieve faster apertures than they really were.
