par hmi difference
#1 siddharth diwan
siddharth diwan
  • 80 posts
Posted 04 June 2005 - 06:39 AM
What is the difference between a par hmi and other hmi's?
#2 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 04 June 2005 - 08:40 AM
PAR stands for Parabolic A-something (aluminized?) Reflector. It' simply a mathematically designed parabolic shaped reflector designed to maximise the output from a source.
Generally, PAR lamps have much more punch, longer light throw and are harsher than regular fresnel HMI's. More bang for the buck, basically. A 6K PAR can many times outshine a 12K or a 18K Fresnel at long distances.
But they come with some drawbacks, too - all the lamps lenses have to be carried in a spearate box and mounted onto the lens and will never give you the same modeled light as a fresnel would. Another real pain is to change this lens when the lamp is hot - you need pliers to do it or your gloves will burn up.
I use PAR's when I need a lot of light, like on exteriors, but otherwise I prefer the light from fresnel HMI's - especially for interior work. But when using small HMI's that you need to tie in to a house outlet or to a small genny, then the PAR's like the 1200w PAR are more useful since they are so much brighter. A 1200 PAR can do some serious edgelighting fully spotted even on a sunny day.
#3 David Mullen ASC
  • 20073 posts
Posted 04 June 2005 - 11:23 AM
Tungsten lights can come in PAR or Fresnel designs too (and open-faced).
A car headlamp is a type of PAR light, a self-contained globe, reflector, and lens unit.
#4 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 04 June 2005 - 05:59 PM
I think it's Parabolic Arc Reflector.
#5 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 04 June 2005 - 08:25 PM
<{POST_SNAPBACK}>
Parabolic Aluminized Reflector (PAR)
#6 Riku Naskali
Riku Naskali
  • 310 posts
  • Finland
Posted 05 June 2005 - 07:57 PM
An electrician I know had some bigass gloves just for that, no pliers needed but he was pretty quick...
I, on the other hand, was too slow and my jacket literally melted... :huh:
