Two Stop Underexposure, with One-Stop Push Processing?
underexposure push processing super 8 short film tri-x
#1 Kurt Cassidy-Gabhart
  • 23 posts
  • Jasper, Indiana
Posted 10 April 2016 - 08:28 PM
Dear Cinematographers,
For a silent short film on which I am working, I desire a grainy and dark texture. I am using Tri-X super 8 black and white film. I thought perhaps that, to my unguided reflection, it would be best achieved by underexposing two stops and then using a one-stop push in processing. Would any untoward complications arise in doing so? Would there be any superior alternative? Thank you in advance.
Sincerely,
K. Cassidy-Gabhart
  • 20187 posts
Posted 10 April 2016 - 08:45 PM
Tri-X b&w reversal Super-8 is already pretty contrasty and grainy, are you sure you need more contrast and grain?  I found it hard enough to nail exposures for Tri-X with regular processing due to its high contrast.  Underexposing it by two-stops and pushing it will pretty much give you a hi-con film effect and, no shadow detail, just hot grainy highlights.
You're going to have to shoot some tests, you may find that 1-stop underexposure with a 1-stop push is all you need, if that.
  • 1
#3 Kurt Cassidy-Gabhart
  • 23 posts
  • Jasper, Indiana
Posted 10 April 2016 - 09:05 PM
Dear David Mullen,
I would like an atmosphere attempting to recreate silent film cinematography, yet still maintaining, in some degree, a modern aspect - in other words, I want coarse and raw images - and so, from my uneducated mind, a "high-contrast effect with no shadow detail, and a lot of hot grainy highlights," if I am visualizing that description correctly, would be preferable. But perhaps I should just stay with something a little less extreme, and shoot at one-stop underexposure and one-stop push. Thank you for replying so quickly!
Sincerest Gratitude,
K. Cassidy-Gabhart
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 11 April 2016 - 01:51 AM
A one stop push to 7266 Tri-X in Super 8 will give you moderately more grain. A two stop push will give a surreal Seurat-like texture, an impressionistic image full of thick, swirling grain. Beautiful, but may be too much for you so shoot a test if possible.
I would not underexpose beyond compensating for the push processing - if you push 1, underexpose 1. Push 2, underexpose 2. Reversal film has so little exposure latitude that you risk not having any detail in the shadows if you underexpose.
#5 Brian Drysdale
  • 5261 posts
Posted 11 April 2016 - 02:10 AM
High contrast for silent films may come from all the duplication over the years, rather than what the films orginially looked like at the tme.
#6 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 11 April 2016 - 11:21 AM
Also, the first thing that comes to mind when I think of the Silent Era is tinting - not necessarily excessive grain.
#7 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 12 April 2016 - 11:28 AM
I got an 8mm Bolex a while ago with the intention of shooting a few rolls of 'film' just for the exercise... but then I found that it seems there is only reversal Tri-X for 8mm (I think there may be/have been a service to take 16mm Tri-X negative stock and punch the requisite holes for 8mm use...).
Anyway... I read also that if one skips the reversal pass(whatever it may be called in B&W...), that Tri-X reversal is 'really grainy' negative...
Would that be a 'solution'... in terms of stills I've always avoided slide/reversal film for the very reason that it is very sensitive to exposure and processing... unless one is intentionally mucking up the look.
Edited by John E Clark, 12 April 2016 - 11:32 AM.
