New Camera Cart / DIT Cart from Matthews Studio Equipment
Camera Cart DIT Cart Kerri Kart
No replies to this topic
#1 Bill Kerrigan
Bill Kerrigan
  • 13 posts
  • Montreal, Quebec, Canada
Posted 10 April 2016 - 09:17 PM
If you're attending NAB 2016, please visit the Matthews Studio Equipment (booth C5437) and I'll give you a demo of the new Kerri Kart.
The cart can be configured as a camera kart, a DIT kart, or a production kart with dolly=slider option depending on what is purchased.
The Kerri Kart was designed around a lightweight, yet robust rolling base capable of transporting a significant amount of gear while still fitting through a standard doorway.
The rest of the kart is built out of standard grip equipment along with a variety of shelving and dolly/slider options.
The Kerri Kart base includes 4 premium pneumatic tires, industry approved Crank-O-Vator wheel forks, and two heavy-duty needle thrust bearings with duper crank pedal brakes.
The 10 strut dolly frame is heliarc welded out of 6061-t6 aircraft grade aluminum, and topped with lightweight perforated aluminum and four junior receive plates for securing the telescoping risers.
Kerri Kart Specifications:
Weight: 61lbs (27kg)
Weight Capacity: 1000lbs (455kg)
Dimensions: 24x46x12.5" (609x1168x317mm)
Height is measured from the ground tot he top of the bottom shelf
Kerri Kart Configurations:
Kerri Kart - DIT
Kerri Kart, Four 20" Risers, Three Sided DIT shelf with Shelf Mounting Hardware, Shelf Bracket Set
Kerri Kart - Camera
Kerri Kart, Four 20" Risers, Four Sided Shelf with Shelf Mounting Hardware, Shelf Bracket Set
Kerri Kart - Pipe Dolly System
Kerri Kart, Four 20" Risers, Pipe Dolly Rigging Kit, Adjustable Width Rail for different sized dollies
More info here: http://products.mseg...ucts/kerri-kart
Bill Kerrigan - DP
Kerrigan Productions Services
514 486 8456 - Office
514 238 9775  - Mobile
bill@kerrigan.ca
http://www.kerrigan.ca
Also tagged with one or more of these keywords: Camera Cart DIT Cart, Kerri Kart
