Options for Dropping particles from overhead?
#1 Roger Alexander
Roger Alexander
  • 46 posts
  • Atlanta
Posted 18 April 2016 - 02:14 PM
I'm looking to recreate something similar to this but with fake snow (plastic) or some other type of particle falling from the sky and umbrella.
picture attahced or at:
https://drive.google...eUdOUzZtQTRqOTQ
I previously looked at options like building this overhead rig and propping up on c stands and shaking it.
Seen at 1:41 in this youtube video https://youtu.be/g_1SAF9eiG0?t=1m41s
But I'm looking for other alternatives that may be easier to transport. Has anyone else used a different type of tool or rig to dump things from above?  I will be in a black cyc studio that does not have a second level to drop stuff from.
#2 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 19 April 2016 - 05:09 AM
Two options come to mind from my theatre background.
One common trick is to take a length of duvateen or any other cloth really and cut diagonal slots in the middle of it. Attach both long ends to some speed rail or wood dowel.  Secure one with some C-Stands and then the other would be attached to some line going through pullies.  You then use the lines to raise and lower the loose end of the cloth which causes the contents to shift back and forther and trickle through the slots you created.  This is much easier to make work correctly with some kind of overhead rigging available, but if the shot is tight enough you could certainly do it with just stands and pipe and some creativity.
The other option that requires more fabrication would be to build a drum (much like what you would see for raffle tickets) with appropriate perforations to its surface to allow your material to trickle out of it, a hinged door with lock for loading your material and some kind of axle going through it so it can spin easily.  Then hang or mount the drum above and use either a remotely controled motor or rope to spin the drum at what ever speed gives you the best effect.
I am sure there are other options, but thought these might help!  Good luck and I'd love to know what you come up with.
