New 1000w Plasma Lights from Hive.
55 replies to this topic
#1 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 19 April 2016 - 08:44 AM
Now THIS is friggin cool! Hive are showing new 1000w versions of their Wasp Plasma PAR, and their Bee Plasma Floodlight.
2.5kw HMI equivalent output, that you can plug into the wall (hell, you can plug two into a 240v wall socket). Zero flicker issues for highspeed work. And all the other benefits of solid state lighting (hopefully variable colour temperature and some dimming capability too).
$8k for the PAR kit and $6k for the Bee floodlight kit apparently
#2 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 19 April 2016 - 08:57 AM
Mark,
I know, right?  The rental shop I blog for has a good relationship with Hive, so I hope to get a demo model down to do a video about it this summer.  I use the Bee and Wasp all the time on shoots.  For me, the 250W Bee has been more useful.  With the new Wasp they provide plastic lenses to go over the PAR and the plastic melts and/or turns yellow, especially if you use a scrim on the light.  The lenses are also kind of wonky - they don't quite work.  I'm interested to see if they fixed that issue since a 1kW light will melt plastic pretty quick.
The other problem I commonly see is that their front protective glass cracks due to shock and vibration.  It looks like they changed their "box" form factor, so hopefully they fixed the glass problem as well.  It's not expensive or difficult to repair, but it's just a pain to have to do it.
The plasma lights don't have all the horrible color rendering problems HMI's do - at least the ones I've experienced.  It looks like they even improved the spectrum on the new bulbs, so I look forward to testing that out as well.  I like not having to melt the talent's skin off, unlike when I use tungsten to get good color rendering.
Stuart
illuma.blogspot.com
#3 Jean Gonzales
Jean Gonzales
  • 37 posts
  • Electrician
  • Antwerp, Belgium
Posted 19 April 2016 - 04:41 PM
Still waiting to get our hands on some here in Belgium..
#4 Phil Rhodes
  • 12167 posts
Posted 19 April 2016 - 08:14 PM
I'd love to know how, considering it's basically the same physics. Still, I am at NAB so I can probably wander over and ask them!
#5 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 19 April 2016 - 08:38 PM
Mark,
Stuart
illuma.blogspot.com
I haven't had a reason to rent out the smaller wattage Hives before, so I'm not familiar with the quirks, but I've been following the technology with interest. Those issues with the plastic lenses sound problematic, hopefully they've been fixed in this latest revision.
Being able to run the equivalent of two 2.5kw HMIs off a single suitcase gennie is a big deal for a lot of the work I do.
Doooo eeeet.
#6 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 19 April 2016 - 09:13 PM
Do Hive make something like a Leko or Molebeam? Because that would be sweet.
  • 1
#7 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 19 April 2016 - 09:24 PM
Yep, they have a leko style attachment.
  • 1
#8 andrew ward
andrew ward
  • 269 posts
Posted 21 April 2016 - 05:22 AM
I think in real world settings all these exciting lights prove to not be as bright as they say and have bizarre designs that no one who actually used them would implement.
#9 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 21 April 2016 - 06:07 AM
What real world experience do you have with any Hive lights to back up this statement?  Maybe your statement should be prefaced with, "IMHO....".
What company (except one whos business plan was to go out of business) would put development money into features that would serve no purpose?
#10 Adrian Sierkowski
  • 7373 posts
Posted 21 April 2016 - 06:18 AM
The biggest issues with Hive thus far are price to own and availability-- they're not a trpically stocked item at least not that I know of, though if they were I'd trade out HMIs for them almost every time (of comparable output, obviously).
If this feature I have goes for this summer, and that's kind of a big if at present, as most of it is remote at night, I'm going to do my best to get a slosh of hives on the
#11 Keith Walters
Keith Walters
  • 2252 posts
  • Sydney Australia
Posted 21 April 2016 - 07:20 AM
I thought they worked on the same principle as a plasma display, but using a white phosphor. In other words, a flat fluorescent tube.
Ironically, they were originally developed as a backlight for LCD panels :-)
#12 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 21 April 2016 - 07:35 AM
From memory, they fire microwaves at a little gas capsule (the bulb), and that excites the gas and generates a bunch of light.
#13 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 21 April 2016 - 12:30 PM
Andrew,
I would highly encourage you to try the Hive lights before forming an opinion.  I think in general they work very well and provide much better color rendering than HMI and many types of LEDs.  The Hive rep claimed that the 250W Bee/Wasp outputs as much light as a 400W HMI, but I've never verified the photometrics.  I find they are more than bright enough for indoor lighting and occasionally throwing a light through a window.  The lights also have just enough color temperature variation to mix with most daylight times and even very blue moonlight.  They don't work well for mixing with tungsten.
The latest mechanical design of the lights are just as practical as any HMI.  There's nothing too unfamiliar about them.  Head, ballast, cables, on/off switch.
I think their biggest issue is that they aren't as-available in rental houses outside major markets.
Stuart Allman
illuma.blogspot.com
#14 andrew ward
andrew ward
  • 269 posts
Posted 21 April 2016 - 01:39 PM
If I say it, its my opinion.
Every company would do that. Otherwise there wouldnt be so many lights. Thered just be the one company with great design cornering the market.
I have zero experience with Hive. You can see from their last iteration of form factor that it has weird design.
Theres a reason no one has these lights.
I hope theyre amazing and come down in price so I can get some. Im generally just saying "isnt it a pity that every time you see an exciting light that is supposed to be a dimmable source with no burn time thats lightweight and punchy it turns iut to not be the back saver you hoped it was". I want it more than you. I gotta use it every day.
#15 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 21 April 2016 - 07:14 PM
I know at least three people who have them and use them as their main lights.  Maybe they just don't have an equipped rental house near you.
They don't dim.  You have to use standard Arri/Mole scrims or ND gels to dim them.  The form factor is actually easier to handle than most HMIs - you can grab the housing without gloves (but not the heat sink!).  They fit standard Arri barn doors.  They're also lightweight - at least the 250W versions are.  Once you see them in person they'll probably seem pretty obvious and less "weird."
I'll be producing a tutorial on the plasma lights for a local rental house this summer.  I might post a link here if no one objects to it as advertising - which it isn't meant to be.
Stuart Allman
illuma.blogspot.com
#16 Mark Kenfield
Mark Kenfield
  • 1160 posts
Posted 21 April 2016 - 09:10 PM
Stuart Allman
illuma.blogspot.com
Please do! It's bloody hard to get a good look at lighting exotica down here at the end of the world.
#17 andrew ward
andrew ward
  • 269 posts
Posted 22 April 2016 - 01:12 AM
They dont dim???
Wtf?
Whats the point then?
Its just an hmi that uses less power? Lame.
#18 andrew ward
andrew ward
  • 269 posts
Posted 22 April 2016 - 01:14 AM
Hey Kenfield. You should do gear reviews.
Its so hard to find a review of say an Area 48 used by someone who knows what theyre doing and compared with similar tools. All these online video reviews where they meter lights etc are useless.
Build your website and reel with the results.
Id do it but I think its all wank.
#19 andrew ward
andrew ward
  • 269 posts
Posted 22 April 2016 - 01:16 AM
Allman, thats good if you like them.
Glad they do what you want.
#20 Leonardo Brocato
Leonardo Brocato
  • 43 posts
  • Rome Italy
Posted 22 April 2016 - 02:28 AM
mh....you can't live without dim?
and this is a problem........there are a lot of good old ways to take down a lamp...
i think that more power and less wattage could be the future.....with the camera stepping to 800 iso.
I don't know the quality of the plasma light because in my county no trace at all but i think could be the future....
leonardo brocato
gaffer rome italy
www.loudphoto.it
