Filter to generate a "uncoated-leans-look"?
What filter you recommend
#1 Philipp Kunzli
Philipp Kunzli
  • 60 posts
  • Zurich & Cologne
Posted 21 April 2016 - 08:25 AM
Hey Everybody
I'm in preproduction for a glossy beauty commercial. Unfortunately, the lenses we have to shoot on, are a set of Zeiss Distagon T 2.1. I know it's the definitely not the right choice but's what we got.
The camera we shot on is an Epic Dragon.
The result should be is a "classic" soft beauty look with a lot of flares, gentle blacks and a lot of soft backlight.
Normally I'd order a set of of old uncoated lenses but as written, it's not possible and the Distagon are quite "dry"...
My thoughts go towards stacking a Glimmerglas with a Black Promist together...
But may be you guys have any oder and better idea.
THX for your support.
Philipp
  • 20251 posts
Posted 21 April 2016 - 10:41 AM
I don't think uncoated lenses are as misty as a GlimmerGlass or ProMist but you should use those if that's the look you want.
If you just want a hazier, milkier look but less misty halation around lamps, you might try an UltraCon, or Smoque filter.
#3 Stuart Brereton
Stuart Brereton
  • 3397 posts
Posted 21 April 2016 - 11:14 AM
I don't think Standard Speeds are necessarily the wrong lenses for the job. They do flare fairly easily, and have a pleasing softness when wide open. You could add some subtle diffusion like a Soft FX to the lens, and then lift your black levels a little in post. I don't think you'd be disappointed.
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 21 April 2016 - 02:46 PM
Other filter options might be Tiffen Pearlescent, Low Con, or Bronze Glimmerglass. Or nets. Or you could try OLPFs with diffusion built-in like the Kippertie Carbon.
#5 Philipp Kunzli
Philipp Kunzli
  • 60 posts
  • Zurich & Cologne
Posted 22 April 2016 - 01:58 AM
Hey Satsuki
Thanks for your replay. What's a OLPF with the Kippertie Carbon? Never heard of it?
#6 Justin Westfall
Justin Westfall
Posted 22 April 2016 - 11:50 AM
Hey Satsuki
http://kippertie.com...con-olpf-carbon
