RGB chroma led lights
#1 Ed David
Ed David
  • 39 posts
  • NYC
Posted 26 April 2016 - 12:13 PM
HI guys
I'm looking at litegear rgb chroma light as a way to quickly make colored party gel looks for shoots.
wondering if there is another LED film lighting manufacturer that also does this?
Just seeing what the options are
thanks
ed
#2 Phil Rhodes
  • 12407 posts
Posted 26 April 2016 - 01:54 PM
Lots. Check eBay for RGB LED strip. The controllers may not be suitable for on-camera use.
#3 Maximilian Motel
Maximilian Motel
  • 31 posts
  • Berlin, Germany
Posted 30 April 2016 - 05:54 PM
I have shot some concerts with RGB LEDs and I absolutely hate them. If it's clean RGB then only one of the color channel is filled with information, so you lose about 66% of the info you'd usually get and it ends up looking very un-detailed and "cheap", in my opinion. I'd rather go with a normal, gelled light source that doesn't output just one RGB channel.
#4 Matthew Parnell
Matthew Parnell
  • 291 posts
  • Electrician
  • Brisbane, Australia
Posted 24 May 2016 - 07:08 AM
Because the LEDs that are used for RGB LEDs emit a very narrow spectrum of light, you miss out on a whole load of colour information that still gets transmitted when using gel on traditional sources. As a result they tend translate less than ideally on camera, especially when you start to move away from super saturated colours.
#5 Phil Rhodes
  • 12407 posts
Posted 24 May 2016 - 08:27 AM
This is certainly true - the saturated colours can visibly clip the gamut of many cameras and the pastels are - well - meh. Someone needs to do an RGB plus white version, which is a lot more flexible.
#6 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 24 May 2016 - 12:02 PM
Ed,
Check out the Arri LC series.  There are also smaller brands, like BriteShot.  BriteShot is based in NY, so that may be a viable option for you.  Both are RGB+W products.
Stuart
illuma.blogspot.com
