XL2--NTSC or PAL?
#1 Jason M Silverman
Jason M Silverman
  • 38 posts
  • dublin, ireland
Posted 07 June 2005 - 05:45 AM
I'm looking to buy an XL2 shortly. I'm living in Ireland, but will most likely buy it in the states, since they are much cheaper, and the Euro is stronger. B&H is the only american retailer I've found willing to sell the PAL version and it costs more than the NTSC. I think I want the PAL for two reasons: 1) Ireland uses PAL 2) the 25 rate should be better for transfering footage to film. Do you all think it is worth the extra cost?
Also, I was wondering if I move back to the USA, will having a PAL camera cause me problems?
Peace
Jason M Silverman
#2 Alvin Pingol
Alvin Pingol
  • 677 posts
  • California
Posted 09 June 2005 - 11:46 PM
I would recommend PAL over NTSC as it will give you a slight increase in resolution as well as better color subsampling (4:2:0 vs. 4:1:1).
Because the NTSC XL2 is capable of shooting 24P, a transfer to film from either region camera should be equally simple.
>>cause me problems?
Only in the fact that you'll need a converter box to view your footage on television; 60Hz sources (fluorescents, TV screens, etc.) may flicker slightly if using PAL standard shutter speeds, like 1/50th, 1/100th, and so forth.
Additionally, an NTSC to PAL conversion will never look as good as PAL to NTSC. Hope this helps...
