3-perf to 4-perf transfer?
3-perf 4-perf
39 replies to this topic
#1 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 16 May 2016 - 11:07 AM
Hello,
I shot a short film on a 3-perf camera on B&W negative, and need to finish it in 4-perf print on a contact printer for a theatrical projection.
Aspect ratio is 1:1.85.
The negative capture area is the same on 3-perf and 4-perf for 1.85, is it not?
As far as I understood it's a fairly simple process that uses some black border cropping on the print.
Is that so? Am I missing anything? Is there anything that might prevent or complicate the transfer to 4-perf print?
Thanks in advance for your help!
Edited by Gleb Volkov, 16 May 2016 - 11:07 AM.
#2 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 16 May 2016 - 11:25 AM
It just needs an optical reduction. Remember, 3 perf is s35 so the frame is wider. It needs optical reduction to fit into an academy frame. It's an expensive process unfortunately.
#3 David Mullen ASC
  • 20182 posts
Posted 16 May 2016 - 11:39 AM
It's either an optical printer conversion, typically you cut the negative, time for an answer print, then knowing the printer light values, make a contact-printed timed IP from the 3-perf negative, then you put that in an optical printer and create a 4-perf 35mm dupe negative, from which you make a print.
Now of course it is possible to put a cut 3-perf negative into the optical printer and create a 4-perf 35mm print directly, but that is less common, both because you put your negative at some risk using a spliced roll but also because all of the printer light corrections would have to be done in the optical printer.  Today, you'd have a hard time finding a lab to do that.
And there is the other issue of getting the negative cut and whether you'd have to make it single-strand (so any fades and dissolves would have to be done in an optical printer and dupes cut it, or done digitally and recorded back to 3-perf and cut in) or A-B roll cut, which then means you would have had to pick standard lab lengths for the fades and dissolves, plus now with an A-B roll negative, you can't easily do a single step blow-up from a 3-perf negative to a 4-perf print in an optical printer (which as I said, was already unlikely).
The more common approach today is to do a D.I., get the negative scanned, color-correct digitally, do all the transitions digitally, and then use a film recorder to put it out onto a 4-perf 35mm negative, then make a contact print.
As Tyler said, the 3-perf image area is "super" and the 4-perf 35mm print projection area is smaller, within "Academy" width to allow a soundtrack on the side of the print.
Which of course brings up sound...
All of this seems rather complicated just to make a print for a short film.  If your intention was to make a print, you should have shot it in 4-perf standard 35mm (1.85 or anamorphic 2.40) so that you could cut the negative and make a contact print.
#4 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 16 May 2016 - 11:53 AM
Thanks for the detailed answer!
It wasn't really a choice of shooting 3-perf to begin with, I was just faced with this fact on site at the last moment. So now trying to figure this out.
The entire film is a one-shot fitting on a single 400' roll of film, 5:30 m.
There's no cutting involved, except trimming the edges and maybe adding titles.
It's completely mute, there's no sound track required for a projection.
So which way would be the simplest for me at this point?
Edited by Gleb Volkov, 16 May 2016 - 11:57 AM.
#5 David Mullen ASC
  • 20182 posts
Posted 16 May 2016 - 11:57 AM
You'd have to consult a lab to see which of the options I laid out is more doable.  Even just putting titles on the roll requires a splice to deal with unless you do a D.I.
So many labs have retired their optical printers that most are going to recommend doing a D.I.
#6 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 16 May 2016 - 12:04 PM
Ok, got it. Will pick it up with the lab. Thank you for your time, that helped me a lot!
#7 Dirk DeJonghe
Dirk DeJonghe
  • 614 posts
  • Kortrijk,Belgium
Posted 17 May 2016 - 04:11 AM
You need both an optical reduction plus a 3Perf to 4 perf change. This is done by having a 3Perf movement in the projector and a 4Perf movement in the camera of the optical printer. Once this is done, you still need to put a mask by exposing a mask film on a contact printer. It has been many years since we did 3 perf work on the optical printer, but all the parts are still there. What is more, when doing direct optical reductions from B&W negative to B&W positive, you may run into halation problems, depending on image content (black halation around backlit hair for example). This is because of lack of anti-halation layer in the B&W positive, this problem is much reduced when going via Interpositive/Duplicate negative.
#8 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 17 May 2016 - 08:18 PM
Thanks for the detailed explanation!
Upon further research I am now trying to go another route:
The projection will be on a Kinoton lab projector, which is supposed to be able to screen 3-perf with a simple flick of a switch.
I'm planning to make a 3-perf (rather than a 4-perf) positive and just screen this way.
If all checks out this is supposed to be a simpler route.
#9 Dirk DeJonghe
Dirk DeJonghe
  • 614 posts
  • Kortrijk,Belgium
Posted 17 May 2016 - 11:56 PM
Very few 3Perf projectors around.
#10 Doug Palmer
Doug Palmer
  • 372 posts
Posted 18 May 2016 - 03:35 AM
But lots of 4perfs.  Is there an economic way I wonder to convert them to 3perf.  And Tyler, I believe you were considering some months back of manufacturing a 3perf/2perf machine  :D Any further thoughts on this ?
It does seem a lot of trouble to make a 4perf print from a 3perf original.  And I guess you'd have similar sorts of problems with 2perf original.
#11 Dirk DeJonghe
Dirk DeJonghe
  • 614 posts
  • Kortrijk,Belgium
Posted 18 May 2016 - 04:32 AM
You would also have to provide optical sound recorders for 3 perf. I don't see that happening.
#12 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 18 May 2016 - 10:29 AM
Far as I know, there aren't ANY 3 perf projectors around. I'd bet there were only a few, 4 perf projectors modified and they're probably long gone.
3 perf came around right at the end of cutting on film, so there would be no reason to project 3 perf camera positive. Filmmakers would simply transfer the negative to video, cut on video, conform the negative and reduction print it to 4 perf.
Adding sound to 2 or 3 perf is easy, Dolby Digital already resides between the sprockets. Adding a timecode track to the outside edge were SDDS is, would also be simple.
My 2 perf and 3 perf table top projector idea would be specifically designed to run a modified format. However, it costs a lot of money to develop. I did see a very similar design recently that kinda threw me off a bit, even though it was 4 perf, the concept was very similar.
#13 David Mullen ASC
  • 20182 posts
Posted 18 May 2016 - 10:44 AM
Ten years ago, all the major labs in Los Angeles could project 3-perf -- Technicolor, Deluxe, FotoKem.
#14 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 18 May 2016 - 11:36 AM
I was told by the blokes over at Fotokem, they still have theirs.
#15 Kenny N Suleimanagich
  • 902 posts
Posted 18 May 2016 - 01:26 PM
I wonder if the 2016 prices of an optical reduction still work out to be less expensive than shooting 4 perf for a 1.85 release?
#16 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 18 May 2016 - 06:10 PM
If you're doing a photochemical finish and you're very tight on shooting ratio, 4 perf winds up being less money then 3 perf, by a very small margin. 2 perf reduction printed and turned into anamorphic, is less expensive. With a digital workflow and scan back to film, 3 perf is the best way to go.
From my understanding, you can't time the film during the IP/optical reduction process. If you COULD, then you WOULD save a considerable amount of money and time. However, I think you need to first time the film and make a 3 perf IP, then do a reduction print to 4 perf. That means you'd be 5th generation by theatrical, which is really bad.
#17 Dirk DeJonghe
Dirk DeJonghe
  • 614 posts
  • Kortrijk,Belgium
Posted 19 May 2016 - 12:24 AM
We can time the film during optical reduction/blow up and make fades as well; our optical printer has the B&H light valves and fader. We did many hundreds of S16 productions where only a few direct blow-ups were made purely for festivals. First a trial print was made on S16 contact positive, then viewed and color correction fine-tuned, then in many cases only one blow-up print was made. We did the same for 3Perf, but no contact print here, only reduction to 4Perf direct.
A properly made direct blow-up from S16, with good lenses and good photography still is mind-blowing quality even today.
#18 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 19 May 2016 - 12:09 PM
So you can do scene by scene color correction through your optical printer?
#19 David Mullen ASC
  • 20182 posts
Posted 19 May 2016 - 01:06 PM
It's been done the other direction too, there were a few gorgeous 70mm timed prints made off of the Super-35 o-neg for "Howard's End" and "Remains of the Day".
#20 Kenny N Suleimanagich
  • 902 posts
Posted 19 May 2016 - 01:57 PM
I didn't realize those were S35!
I was actually recently watching some deleted scenes from "Remains of the Day" on youtube and they look like they're from a workprint – the image is 1.37 and you can see the boom pole dipping into the frame occasionally, with dust spots here and there. I was thinking about projection mattes and such, and wondering how common something like that was in the photochemical era: shooting full-aperture for a 1.85 finish.
