Any ideas how they did this?
#1 Michael Townley
Michael Townley
  • 4 posts
Posted 19 May 2016 - 07:39 AM
Anyone happen to know or an educated guess as to how they lit this? Seems to be a revolving light but the rotations and the spotlight doesn't seem to match the shadows.
http://www.amc.com/shows/the-walking-dead/video-extras/trailer-shadows-the-walking-dead-season-6-premiere
I can see there is a lot of post work done to it with the transitions.Look at the way the light is hitting the talent. Its at an angle on some sort of motor device. But if you watch close, the light illuminates the right side of the subject first, then washes over them from left to right. if this was done by just rotating a light on a wheel, it would illuminate left to right. Am I wrong?
#2 JD Hartman
JD Hartman
  • 1807 posts
  • Edison, N.J. U.S.A.
Posted 19 May 2016 - 08:19 AM
Fixed light, rotating gobo?
#3 David Mullen ASC
  • 20462 posts
Posted 19 May 2016 - 10:18 AM
The light is clearly rotating in a circle above them, it doesn't switch direction but comes from behind and then around in front because the actor is standing in the center of the ring and the light is angled inward.
#4 Michael Townley
Michael Townley
  • 4 posts
Posted 19 May 2016 - 10:26 AM
Thanks David. I realize its on a rotating motor above of some sort, at an angle. I guess I was just curious, when the light is behind them, they must dim it fully as to not silhouette the talent, and then bring it back up when it gets to like a 45Deg behind talent. Im curious as to how they were able to match the dolly in and the light rotations for every actor. Because they would need to match the frames with each talent at the right moment the light and frame is correct.
#5 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 19 May 2016 - 01:17 PM
Michael,
They could just shoot it in 6k and crop to match head size in the edit.  There's no reason it has to look exactly like the final product during the shoot.
The trick was maintaining the push-in speed, which might have been a Technocrane or a really good dolly grip - or they just modified the speed in post to match between shots.
Stuart
#6 David Mullen ASC
  • 20462 posts
Posted 19 May 2016 - 01:42 PM
I'm sure they practiced so that the length of the move and the speed was correct for the light to make the number of full rotations, one for each actor... I didn't count them but let's say there were six actors so six 360 degree rotations had to happen by the end of the dolly move. At that point they could have done a motion control rig or simply marked the track to know where the dolly had to be passing for, let's say, every right, center front, left, and center back position of the light. And yes, I would have probably shot it oversized so some reframing could be done in post. For a 1080P finish, even shooting in 2.8K Arriraw might have been enough to work with though I suspect 5K or 6K on a Red was more likely. Or maybe a 4K camera.
#7 Nicholas Kovats
Nicholas Kovats
  • 526 posts
Posted 19 May 2016 - 07:12 PM
What Red camera at 6K? The Walking Dead is shot in Super 16 format with Arri 416 camera.
#8 Nicholas Kovats
Nicholas Kovats
  • 526 posts
Posted 19 May 2016 - 07:16 PM
A bit dated but relevant, ie http://www.studiodai...e-walking-dead/
#9 David Mullen ASC
  • 20462 posts
Posted 19 May 2016 - 07:42 PM
The Red Dragon sensor is 6K.
This is a promo spot so it doesn't mean it was shot in Super-16 like the series is.
