Help diagnosing problem with Nikon R10
#1 John Woosley
John Woosley
  • 19 posts
  • Kansas City, MO
Posted 30 May 2016 - 08:45 AM
Hi all,
So I got what I thought was a good deal for Nikon R10 that said it was untested, hoping to get lucky. Unfortunately there is some problems with the camera I need your help diagnosing to see if it's worth repairing or if I should just try to re-sell. When I put batteries in the camera, the only electrical piece that works is the slow zoom. No lights etc. The other issues is it looks like there are some kind of spots on the lens, but beneath the main glass. Is this worth repairing? Thanks all.
JW
#2 Andries Molenaar
Andries Molenaar
  • 712 posts
  • Amsterdam
Posted 30 May 2016 - 08:54 AM
Use the white button batterytest. The red light should come on.
Check/clean the three contact surface of the batteryclip.
Zoom should work in slow and fast when the motor is OK. It needs the 4.5 and 9 volts.
Is the lightmeter needle working? Is the EE knob working when pulled out in that it adjusts the aperture?
Be sure to have the Rew/Forw switch in Forward. When on Rewind it does only 100 frames and then stops and may appear to be broken.
The lens cleanliness is hard to judge from a distance.
#3 John Woosley
John Woosley
  • 19 posts
  • Kansas City, MO
Posted 30 May 2016 - 09:29 AM
Unfortunately the battery light does not come on, despite the motorized zoom working. Lightmeter does not respond, however I can adjust the EE but it doesn't seem to go past 2 (maybe 4 I'm away from it and can't remember).
I'd have to double check the reverse/forward switch, but the shutter does not activate when I press the button.
I cleaned all the battery contacts as well, but it does appear there is some very minor corrosion.
#4 Andries Molenaar
Andries Molenaar
  • 712 posts
  • Amsterdam
Posted 30 May 2016 - 10:04 AM
It is about the three contacts on top of the clip where they interact with the camera when inserted. These should be inspected too :)
#5 John Woosley
John Woosley
  • 19 posts
  • Kansas City, MO
Posted 31 May 2016 - 08:51 AM
I I think I did...but I'll have to check again when I'm back to the camera. Is there a way to improve the connection between the contacts and camera? Some conducting material perhaps?
#6 Andries Molenaar
Andries Molenaar
  • 712 posts
  • Amsterdam
Posted 31 May 2016 - 09:09 AM
I would attemp with a brass brush, very fine sanding paper or a hard eraser.
You could also make sure that there is voltage on the contacts by testing these with a voltmeter.
Maybe one of the springs or pads in the clip isnt contacting properly.
It is obvious that there is no 9 volt as the fast zoom would need that. The slow zoom runs off the 4.5
To increase pressure on the pads you could attempt to fit a piece of thin cardboard underneath the clip.
