Mitchell S35R / Mark II take-up friction
11 replies to this topic
#1 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 07 June 2016 - 08:28 AM
I am bringing a Mitchell S35R (or Mark II...) back to life for a short test: all seems to work perfectly except for the take-up friction, which is pulling the film way too hard. Loosening the set screw didn't solve the problem: a sort of all or nothing effect. So I have cleaned the discs which were indeed really dirty. Now my question is: should I oil or grease these discs? I hope somebody can help... (and yes I know, the best for this camera would be to have it properly serviced, but that is out of the question for now, and here, in the Netherlands...)
#2 Mark Dunn
Mark Dunn
  • 2781 posts
Posted 07 June 2016 - 09:15 AM
I'm sure you will get a better answer, but my guess is grease, because oil could splash onto film. So what you cleaned off was probably congealed grease. I recently stripped down a Steenbeck and the grease had turned into a flexible toffee-like solid.
What sort of grease I have no idea. I used a general-purpose lithium automotive grease, not a high-temperature type. If it's for your own use you could use what you like-you can always remove it afterwards.
Edited by Mark Dunn, 07 June 2016 - 09:19 AM.
#3 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 08 June 2016 - 01:35 AM
Thanks Mark, I thought the same. However since I don't know which material the central discs are made of (black plastic-like) I am hesitating.
#4 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 08 June 2016 - 02:06 AM
Isn't there a brake system on that supply assembly?
#5 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 08 June 2016 - 04:11 AM
On the feed sides of the magazines there are brakes indeed. For the take-up there is an adjustable friction built into the camera itself: it's a gear between two discs. This brings me to another question I only thought of now: the belt driving the magazine isn't supposed to slip is it? The old leather belts with the camera are shrunken and unusable, so I made new ones from 3mm diameter "ropanyl" (the green stuff you can weld yourself for every size of belt). This material is definitely not slipping easily.
#6 Mark Dunn
Mark Dunn
  • 2781 posts
Posted 08 June 2016 - 04:16 AM
I know nothing specific, of course, but I'm thinking that a film takeup needs some sort of clutch arrangement to allow for the increasing radius of the roll.
So perhaps you're right. A fresh leather belt would slip. Maybe you need some thongs. IIRC the Arri 2C uses leather belts for takeup.
The plastic could be some variation on Bakelite. The camera may be old enough.
Edited by Mark Dunn, 08 June 2016 - 04:22 AM.
#7 Kenny N Suleimanagich
  • 902 posts
Posted 08 June 2016 - 08:04 AM
The Arri IIC mags are gear driven - as are the succeeding, backwards-compatible generations (III, 435).
#8 Gregg MacPherson
Gregg MacPherson
  • 1956 posts
  • New Zealand
Posted 08 June 2016 - 08:24 AM
A gear may transmit the drive to a magazine, but there has to be a means,  after the gear in the drive train,  to allow slipage on a takeup system.  One can assume a friction disk or belt.  Yes?
#9 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 08 June 2016 - 09:27 AM
Mark, yes, the discs could well be bakelite, they look like it, this camera is from the late '60-s I guess.
Gregg, exactly, and in this case one of the gears is not fixed on its shaft, instead it is between 2 friction discs which are connected to that shaft. A spring presses this assembly together, you can adjust this pressure with a thumbscrew.
I am not familiar with the older Mitchells (wouldn't mind to correct that though...;-) but since the magazines are interchangeable between the S35R and the older models I guess the way the slipage works should be the same.
#10 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 08 June 2016 - 10:46 AM
There should be some sort of slippage, but I would imagine it being within the assembly, like most cameras.
Riddle me this, when you cleaned the disks, during re-assembly, did you accidentally squish the assembly too much? It does require some sort of gap.
Also, shouldn't there be some sort of "slip" material in those disks that MAYBE wore away?
#11 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 08 June 2016 - 02:36 PM
Tyler, after re-assembly, I started with much lower pressure on the assembly than it was set to, but that does not guarantee that there was not something wrong of course. When you set the pressure really low those discs still come apart( you can see the side of the assembly when you open the door for the "inverted" 400 ft. magazine at the back of the camera).  And yes, I hope not, but it could very well be that too much material wore away. At least not to the surface of the 3 metal pins with which each black disc is attached to the side of the gear...
#12 Emiel de Jong
Emiel de Jong
  • 17 posts
  • Eindhoven
Posted 31 October 2016 - 08:22 AM
For those interested in what happened further: after some advice from experienced people I ended up flattening the slightly grooved metal discs on an optical flat, and roughing up the surface very slightly. This made the slip clutch perform in the right way, becoming really hot though. For our small shoot (test and actual: just some 600 ft. ...) this worked, but I did put some oil on the discs again to prevent high temperature. If we use this camera again I will have it properly and professionally serviced first.
In the meantime our short "The Creature From Under the Bridge" was shown at the Amsterdamned 2016 Filmfestival
http://amsterdamnedf...ival.nl/#shorts
We had the negative cut at HaghefilmDigitaal, check out their facebook page: there are some nice photos on it of the actual splicing. For me it was the first time I used Vision 3 (and film again in general for the first time in about 10 years) and what I did not expect was the "softness" of the colors: I like the more saturated and hard colors with deep blacks I was used to, something-as I understood- is not possible anymore, all analog, with the print film available right now. I am looking forward to everyone's thoughts on this, though maybe it doesn't really belong in this topic.
