Matth Bounce/ Poly Bounce/ Grifflon
lighting overheads rags bounce fabrics 12x12
18 replies to this topic
#1 Kenny Keeler
Kenny Keeler
  • 57 posts
Posted 15 June 2016 - 01:10 AM
Hey All,
This may be a random and or simple question. But recently when talking to a few DPs they have mentioned using large Matth Bounce for a night exterior scenes etc. I tried to google this to research and see what this Matth is all about but not much comes up. I did have poly bounce come up. I have used Black and white Grifflon before but never Matth or Poly Bounce.
Any buddy know the technical differences between the 3? How reflective is one compared to the other etc.
Thanks! I really wanna know what these tools can offer.
  • 20182 posts
Posted 15 June 2016 - 01:14 AM
Probably "matte" not "matth" unless they meant "Matthews" which is just a grip equipment company.
Oh, I see that Matthews calls their silver lightweight board "Matthboard"... Never heard the term before:
http://www.filmtools...board-fill.html
It's just shiny silver on one side and stipled silver on the other, the stipled silver would be similar the Roscoflex material:
https://www.rosco.co...menuReturn=film
#3 David Mullen ASC
  • 20182 posts
Posted 15 June 2016 - 01:26 AM
Beadboard, called "poly" in other countries (for polystyrene), is very soft as a surface though often people tape something to one side of beadboard for a different surface, could be stipled silver, could be shinier white board, could be muslin cloth, etc. 8' X 4' tends to be the largest possible size.
Grifflon is a tough shiny material similar to a tarp used to protect something from the elements. See:
http://www.theragpla...om/bounces.html
#4 JD Hartman
JD Hartman
  • 1786 posts
  • Edison, N.J. U.S.A.
Posted 15 June 2016 - 06:28 AM
"Matth Bounce",  Matthews (MSE) part #319011, other might call this a black and white untrabounce.
#5 Vivek Venkatraman
Vivek Venkatraman
  • 103 posts
Posted 15 June 2016 - 09:09 AM
David,
In your opinion other than thermacol [which I think is polystrene] What would be a could reflective surface that can bounce sunlight without creating a hot spot ?
Does Muslin do the trick ? Or would you recommend ultrabounce ? Also is this the same bleached Muslin that is available in the Lee filter kit ?
#6 David Mullen ASC
  • 20182 posts
Posted 15 June 2016 - 10:01 AM
Muslin would be the softest bounce but UltraBounce is almost as soft but more durable.
#7 David Mullen ASC
  • 20182 posts
Posted 15 June 2016 - 10:13 AM
http://www.filmtools...x12maulcat.html
Yes, it looks like Matthews likes to stick the prefix "matth" over their versions of common grip products, so MatthBounce is UltraBounce.
#8 JD Hartman
JD Hartman
  • 1786 posts
Posted 15 June 2016 - 03:45 PM
Ultrabounce is actually a trademarked term owned by The Rag Place.  So Matthews and others can't use it as a product name.
  • 1
#9 Kenny Keeler
Kenny Keeler
  • 57 posts
Posted 15 June 2016 - 05:34 PM
Ooooh ok that make sense! Thanks guys for the links and info!! A case of the multi named item  :lol:
David have you used Claycote before?
#10 David Mullen ASC
  • 20182 posts
Posted 16 June 2016 - 02:50 AM
Not sure there is much difference between UltraBounce and Claycoat, again, maybe it's just a trademark issue... A grip could answer this better than me. At some point, if the surface is white and matte enough, which you choose depends more on other factors, like how tough does it need to be, will it get wet, does the wind have to pass through it, does it need to be able to be pulled tight on a frame without visible seams because it will be photographed as a white background?
#11 JD Hartman
JD Hartman
  • 1786 posts
Posted 16 June 2016 - 05:57 AM
About halfway down this page: http://www.advantage...cifications.htm
Apparently Claycoat is a less efficient bounce than Untrabounce, Mathbounce, Superbounce, etc.
When would you ever pull out the Griffolyn instead of one of the above?
Edited by JD Hartman, 16 June 2016 - 05:58 AM.
#12 David Mullen ASC
  • 20182 posts
Posted 16 June 2016 - 07:34 AM
"Less efficient" could mean that it is softer, more matte, or it may just mean that it isn't as white.
#13 Alexandros Angelopoulos Apostolos
  • 471 posts
  • Athens
Posted 16 June 2016 - 10:49 AM
Has anyone ever used linen in the film industry?
#14 David Mullen ASC
  • 20182 posts
Posted 16 June 2016 - 10:55 AM
Sure, I use cheap white bedsheets to bounce light off of, I drape them over furniture, tape them to walls or ceilings, etc.
  • 1
#15 John Holland
John Holland
  • 2286 posts
  • London England
Posted 16 June 2016 - 12:47 PM
David Watkin did this 40/50 years ago bounced and in front of Brute Arcs.
#16 David Mullen ASC
  • 20182 posts
Posted 16 June 2016 - 01:38 PM
You just have to keep in mind that a household bedsheet hasn't been treated with any fire retardant so you want to be careful with how much light you pound into them.
#17 Kenny Keeler
Kenny Keeler
  • 57 posts
Posted 16 June 2016 - 01:53 PM
True, I mainly had this question pop up because I was surfing the internet and then talking to others I said to myself hmmm there are a ton of Rags that I have no idea what the heck they do ha. I mainly use Ultra bounce, Bead board, and Rosco Flex on bead board for my go to bounce surfaces. I guess the many list of different rags all have there uses depending on the circumstances. as well as their names depending on the company making them. Thanks again David for the the advice!
Thanks JD awesome website! Now thinking about it I remember a show I was on using Griff during a rain scene because it was a little more thick than ultra bounce even though they say that is rain proof as well. When I worked at a rental house I remember getting a wet Ultra Bounce back and it had dried in some places and stuck together and had a yellowing tint to the areas.
Bed sheets are great if you get a really stark white ones they work great just for fill with out bounce a source directly into it. As David mentioned be carful getting lights to close they will go up in flames if they get too hot!
Or you could play around with different colors, say tan or something close to a burlap color if you are trying to get a warmer feel. Could be a poor mans version of unbleached muslin.
  • 1
#18 JD Hartman
JD Hartman
  • 1786 posts
Posted 17 June 2016 - 05:52 AM
I've used a Griffolyn outdoors as a rain cover for equipment carts.  Ran out or tarps.
Had an Ultra/Math/Super bounce that also had a yellow discoloration.  Thought it was some kind of stain or burn and it wouldn't wipe off with any kind of cleaner.  Later the yellow just disappeared.  Read somewhere that these rags can get a mildew stain if put away wet.  Maybe it some type of growth and the sunlight killed it?
#19 James Cocker
James Cocker
  • 1 posts
  • Grip
Posted 03 February 2017 - 06:06 PM
So...if Griffolyn was my only option for bounced light, what would be its drawbacks?  The bounced light would be pretty hard - rippled reflections in the wind - noisy in the wind?
My goal is to keep my kit small and full of multi-use and easy to care for items. I'm guessing 8x8 Griff can be easy to clean. Is it larger than ultrabounce when folded?
Thanks, JC
