Need Help, Beaulieu 2008S Battery Wiring
Super 8 Beaulieu Beaulieu 2008 Beaulieu Battery
#1 Gabe Agoado
Gabe Agoado
  • 80 posts
Posted 10 July 2016 - 10:09 AM
Hello,
I have the Beaulieu 2008 Reflex Control model with the single contact in the center and the ground contact on the side.
It was supplied with a wire to connect it to a battery. I'm not sure where it's from, but it does say "Made in Germany", so I'm thinking it could be an old model from Chambless or Wittnauer. The other side of the wire has a 6-pin DIN connector with the center pin broken off. There are a red and yellow wire each soldered to a separate contact, and a green and blue wire soldered together to another contact.
I'm wanting to make a battery pack for this, either by using a female DIN plug or cutting off the DIN output and connecting the red/black wires from the battery pack directly. I've already figured out that I need two separate 2.4v packs, with 4.8v going to one contact and 2.4v going to another. What I need help with is figuring out what each wire from the dummy battery represents. I am thinking that the green and blue wires soldered to 1 contact are for 4.8v, and either the red or yellow is for 2.4v and the other is ground, but I can't find any corresponding information when I'm looking up wire color codes for Germany.
Edited by Gabe Agoado, 10 July 2016 - 10:17 AM.
#2 Andries Molenaar
Andries Molenaar
  • 712 posts
  • Amsterdam
Posted 10 July 2016 - 01:23 PM
Check here:
http://super8man.fil.../super8_10.html
#3 Gabe Agoado
Gabe Agoado
  • 80 posts
Posted 10 July 2016 - 03:37 PM
I've visited that page before, unfortunately there is nothing there that refers to what I could use help with. Thanks for the suggestion though.
#4 Dom Jaeger
Dom Jaeger
  • 1922 posts
  • Melbourne, Australia
Posted 11 July 2016 - 05:04 AM
If there are only 2 contacts on the dummy battery (and presumably the camera too) then you only need 4.8V don't you? The 2.4V centre tap needs a third contact.
If you can access a multimeter it's very simple to check continuity and trace the wires back to the dummy battery contacts, the centre being +4.8V, the edge ground.
