How to shoot sky surfers?
#1 Nitai Lev Oren
Nitai Lev Oren
  • 41 posts
  • Israel
Posted 11 July 2016 - 11:32 AM
I needed to do a project and shoot sky surfers,
but the issue was that I tried to shoot it with a DSLR and I failed to track focus and to stabilized the shot on the shoot itself
because the skysurfer moves very fast and he's getting on and off from the depth of field of the camera.
so I went and rented Panasonic 160 and again the same problem to track focus.
It was way way better from the DSLR because this camera has a back focus.
and another problem was shooting with a shoulder mount because my hands got very exhausted after 5 minutes straight.
so I asked the man on the rental shop what to do, he said I need to rent the PMW350 it's for sports and It will track focus.
but this cameras rent is high it's like 250$
so do you know other cameras that can track focus or have continues AF
Here is the footage from the P160:
Edited by Nitai Lev Oren, 11 July 2016 - 11:39 AM.
#2 Jan Tore Soerensen
Jan Tore Soerensen
  • 185 posts
  • Norway
Posted 13 July 2016 - 07:24 AM
What about 4k, and pushing in in post? Should make it easier to track when filming, because you don't need to be as close to the subject. You can also use a stabilizer in post.
#3 Nitai Lev Oren
Nitai Lev Oren
  • 41 posts
  • Israel
Posted 13 July 2016 - 11:49 AM
thanks. but 4K there is the problem the object gets out of focus.
Edited by Nitai Lev Oren, 13 July 2016 - 11:49 AM.
#4 Jan Tore Soerensen
Jan Tore Soerensen
  • 185 posts
  • Norway
Posted 13 July 2016 - 11:52 AM
It really depends on which aperture you're shooting at, and focal length of course.
#5 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 13 July 2016 - 12:18 PM
When your title said 'sky surfer', I was thinking of something like this:
How-to-Learn-Extreme-Skysurfing-History.
Which really requires that someone be following during the jump with a camera mounted on their helmet like this:
As for ground based capture of someone in the air... very difficult without mechanical tracking.
Essentially one focuses at 'infinity', and then tracks the object.
#6 Nitai Lev Oren
Nitai Lev Oren
  • 41 posts
  • Israel
Posted 13 July 2016 - 12:26 PM
ok so how do u call this aeroplane but for kids?
and do you know mechanical tracking device that can do this job?
#7 John E Clark
John E Clark
  • 850 posts
  • San Diego
Posted 13 July 2016 - 12:40 PM
Those would be called 'gliders' in English.
For hand tracking, a good tripod, and easy control of the tripod head.
I think this is why someone recommended a 4K approach, this would allow you to capture a 'large' frame, and then crop to 2K, using both hand tracking in capture, and some form of 'object' tracking in say After Effects. (I don't know if Premiere has tracking filters...).
A zoom lens exacerbates the problem of 'shaky tracking', but is required for getting the glider to be anything but a small dot.
With shooting 4K, you don't so much 'zoom in' as just eliminate unnecessary pixels.
At more than 50 feet you should be ok with the focus at 'infinity' and say an f/8 setting.
#8 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 13 July 2016 - 12:49 PM
Since you are shooting in day light you really should stop down your lens to make your depth of field very wide and eliminate your focus issues on the long lens.
And you should 100% be using a fluid head tripod, hand held or shoulder mount will be too shaky and you will kill yourself.  I would also recommend shooting with a circular polarizor to get rid of the glare of the sky and help your subjects stand out from the background a bit more.
#9 Nitai Lev Oren
Nitai Lev Oren
  • 41 posts
  • Israel
Posted 13 July 2016 - 04:42 PM
ok but which lens do you recommend and how do I set up my lens to focus infinity?
and does it more easy to track 4K footage then regular HD footage?
