Single shot
#1 Kugan S Palani
Kugan S Palani
  • 22 posts
Posted 13 July 2016 - 12:30 PM
Sequence -Lengthy single shot,camera follows a guy walks on the road for 100 meters distance and drive bike for a half kilometre and step down,walks on the stair to the third level and then he falls from their.
I need to shoot this sequence in single shot
#2 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 13 July 2016 - 12:53 PM
Sounds like you would want a steady cam or gimbal with the operator on the front of a vehicle that can follow the actor while walking and biking then step off and move with him up the stairs.  Doesn't sound like there are any chances to hide cuts in the wide open like that.
#3 Kugan S Palani
Kugan S Palani
  • 22 posts
Posted 13 July 2016 - 02:11 PM
Thanks shawn, but camera will be outside the house , arm up and travel till terrace, character will reach terrace through stairs
#4 David Mullen ASC
  • 20191 posts
Posted 13 July 2016 - 02:36 PM
Following the walker / biker could be done with Steadicam / gimbal operator on the nose of a camera car, but to rise up to a second floor balcony would require the operator to step up onto a crane, so unless you can frame out the crane parked in front of the house by the terrace so that the operator can back onto it, you might have to find a way to hide a cut.
Or maybe shoot this with a drone.
#5 Kugan S Palani
Kugan S Palani
  • 22 posts
Posted 13 July 2016 - 02:39 PM
thank you David sir.
#6 Kugan S Palani
Kugan S Palani
  • 22 posts
Posted 14 July 2016 - 03:08 AM
Big deal
With your advice only I can able to achieve this commercial . Thank you very much David Mullen sir.
#7 Shawn Sagady
Shawn Sagady
  • 171 posts
  • Maryland
Posted 14 July 2016 - 03:18 AM
Ah didnt realize you had to raise up, then yes a drone would be your best bet here since it will allow the camera to travel up with out a crane etc.  Semi long lens would be helpful just to give you some buffer from the actor.  Will you need location sound at all?
