Poor Shooter's Breise
beauty breise lighting
#1 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 15 July 2016 - 10:10 PM
I was watching Matt Workman's discussion about a Pantene commercial and saw the use of a Breise forcus 140 as a key light.  Is there a poor shooter's semi-version of a Breise that gives a similar look?  I work in a market where there aren't many large budget commercials, so a Breise basically doesn't exist here and no one is going to pay to truck one down from L.A.
I did like the silver stipple on hair look, so I might try that on a web series sometime soon.  Thanks for that Matt.
Stuart
illuma.blogspot.com
#2 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 15 July 2016 - 10:28 PM
K5600 make a new Briese-style umbrella for their Jokers. I think it's called the Kurve and comes in a few sizes. Don't know if they are actually shipping yet.
#3 Stuart Allman
Stuart Allman
  • 198 posts
  • San Diego, CA
Posted 15 July 2016 - 10:57 PM
I wonder if it fits on other fixtures with a Chimera speed ring?  I'll have to check it out.  Thanks for pointing out that product.
I thought about it a little more and the characteristics of the light are a beam with a large square area, but focused in direction.  I'm curious if a large parabolic softbox, like the ones offered from Chimera, and a reasonably selected grid over the front would give a similar look (80-90%)?  It certainly would have square area and the grid would add directionality/fall off.  I haven't found a photo yet of just the Breise against a wall to know how the edge falls off.
The only characteristic I see missing is the bulb in the center, which *might* create a slight hard shadow.  Silver mirror backing can only reflect about 80% of the light hitting it, from what I know.  So it's not like the interior of the parabola will ever be as bright as the bulb itself.  I just don't know if it's noticeable.
Thoughts?
Stuart
illuma.blogspot.com
#4 Stuart Brereton
Stuart Brereton
  • 3489 posts
Posted 15 July 2016 - 11:30 PM
You could try a Photoflex Starlite in a silver Octobox without the front diffusion. Not exactly the same thing, but they are a lot cheaper, and the principle is the same.
#5 Nor Domingo
Nor Domingo
  • 37 posts
Posted 17 July 2016 - 04:10 AM
There is also Dedolight's PANAURA that looks similar to the Briese. I've never used a Briese though so I can't compare it.:-)
#6 Jean Gonzales
Jean Gonzales
  • 37 posts
  • Electrician
  • Antwerp, Belgium
Posted 17 July 2016 - 08:02 AM
Broncolor has their Para line. They are not cheap, but cheaper then Briese.
http://www.bron.ch/b.../products/para/
