Advice for Wireless Video from Arri 435ES
arri 435 wirelss SD HD-SDI analog
#1 Christopher Lew
Christopher Lew
  • 32 posts
  • Toronto Canada
Posted 18 July 2016 - 04:59 PM
Hello,
I'm looking for advice if anyone has done this themselves!
I’m trying to up-convert the analog composite signal from a 435ES video tap to an HD-SDI signal so I can get a wireless feed going through a teradeck. What I’ve found online to be the best solution so far is the Aja V2 mini converter.
The Decimators (specifically the MD-DUCC) are apparently very misleading and can't convert the analog CVBS signal to SDI, although the Decimator 2 can down-convert.
Has anyone tried/tested any of these methods or found a way themselves?
Chris
#2 Kenny N Suleimanagich
  • 902 posts
Posted 18 July 2016 - 05:39 PM
I do it often with my 416. It's far easier to do with HDMI and cheaper you can get a BNC to RCA adapter and run it into a composite video to HDMI box(these are very found online easily), powered by a USB battery. Unless you're willing to monitor in the analog world, many rental houses have Transvideo TX/RX for these cameras.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 18 July 2016 - 07:31 PM
From a recent thread: http://www.cinematog...280#entry455525
Seems to be a common issue these days. Someone could make good money retrofitting all these old videotaps to HD-SDI...
#4 Christopher Lew
Christopher Lew
  • 32 posts
  • Toronto Canada
Posted 18 July 2016 - 09:44 PM
Thanks for sharing Satsuki!
#5 Matej Pok
Matej Pok
  • 72 posts
  • Bratislava, Slovak Republic, Europe
Posted 28 July 2016 - 02:04 AM
You can also use analog wireless system - Transvideo Titan, which are very cheap these days (200 €) and has far more usable range than Teradek (exactly about twice the lenght). It's also simpler solution.
Also tagged with one or more of these keywords: arri, 435, wirelss, SD, HD-SDI, analog
