Running 240V 4K HMI off 16A 3P - Possible?
#1 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 09 August 2016 - 09:19 AM
Hi everyone,
A quick question:
I'm in 240V land!
I'd like to run a 4k par.
I only have a 240v 16A 3-phase outlet on location. No genny currently.
Normally I would juice the 4k with a 32A 1P cable from a distro and bob's your uncle, since the 4K would draw roughly 20A at 240V.
I was told by a gaffer friend of mine that if the wiring is correct -  it's possible to run a 4k hmi fixture of this 16A 3P outlet with a cable converter from 16A-3P to 32A-1P.
I trust the guy, but I'm not entirely sure why this should work, has anyone worked this setup (reminder: 240v land) and can confirm that?
#2 Phil Rhodes
  • 12369 posts
Posted 09 August 2016 - 12:00 PM
Neither am I. What's his explanation? With no transformer involved, I'm not sure how this is going to work other than by running the 4K load off one phase of the 16A and hoping that 16x240=3840 is close enough to 4000 to work. Which it might be. For a while. Maybe. And the mains won't actually be 240, so you don't even get that.
Personally, I wouldn't.
#3 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 09 August 2016 - 12:55 PM
The guy was on set so we didn't get to discuss it much, that's why I'm asking.
What you wrote were my thoughts as well, but this solution really sounded unreliable.
But when I think of it, It's a 2.5K/4K fixture, so maybe I grab both bulbs and give it a try? Worst case I go back to 2.5K which was the original plan...
Edited by Gleb Volkov, 09 August 2016 - 01:10 PM.
#4 Shachar Alfie
Shachar Alfie
  • 16 posts
  • Israel(Middle East)
Posted 09 August 2016 - 01:17 PM
You can find two 16A 1phase outlets that uses the same phase but uses different "16C Circuit Breaker" and make an adapter.
:ph34r:
#5 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 09 August 2016 - 01:27 PM
Hey Shachar!
You mean regular household outlets?
I don't really have the time to build and test that properly, but just out of curiosity - how would you go about that?
We have to make sure the distribution of load is roughly equal in order for it to be stable, don't we? Not something I can DIY at home, I sense...
#6 Shachar Alfie
Shachar Alfie
  • 16 posts
Posted 09 August 2016 - 02:22 PM
theoretical info only!!!
yes
phase to phase voltage = 0V (same phase) use a fluke for testing.
use regular household outlets that use different "16C Circuit Breaker"
connect the phases.
connect the N(0).
you will need to put together a protection system so no one will die. an electrician can do it.
#7 JD Hartman
JD Hartman
  • 1801 posts
  • Edison, N.J. U.S.A.
Posted 09 August 2016 - 03:26 PM
Doubt that you will have enough mains power to strike the 4k lamp without tripping out.  Even with an electronic ballast.
#8 aapo lettinen
aapo lettinen
  • 1190 posts
  • Finland
Posted 09 August 2016 - 03:57 PM
I have done the 3-phase 16A to 32A for 4K par thing numerous times, never had a problem with it. the arrisun had a 3-phase input though. I have even used a 16A to 32A adapter with a 150m of 32A cable and a 4K and had no striking problems or anything.
if using the one phase model it surely won't work and will blow up some fuses though.
Using a 2.5K on a single 16A 240v is very common here and will always work so maybe just changing the bulb to 2.5K so you can manage with a single schuko?
#9 Gleb Volkov
Gleb Volkov
  • 12 posts
Posted 09 August 2016 - 04:28 PM
That's interesting! You mean you had 32A 3P input? Why would it have that?
The backup plan is using the 2.5K bulb, I'm trying to figure if I can push it or not.
