S-VHS
21 replies to this topic
#1 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 11 June 2005 - 11:41 PM
Ok I want to use S-VHS its cheap and so are the cameras. How do I edit S-VHS though? I see editors but Im not sure if its the total thing.
#2 nao_yoshino
nao_yoshino
Posted 12 June 2005 - 01:04 AM
Hey Aphix,
Just my own take on this - involves spending a little bit of money, but you could be editing on Final Cut or Avid DV or Premiere etc., if you got yourself a computer with a video capture card (s-video and/or composite). It'll make your DVD production real easy (if you're distributing on DVD) and once it's on the computer, you can upload it to indpendent film sites etc. You probably already know this - sorry if I'm beating a dead horse!
All depends on what output the S-VHS camera can support. You'd still get the good ol' S-VHS look but the editing capability/flexibility of a professional editing suite (color correction, image transformations etc.)
Otherwise, I know that my old high school used the old Panasonic AG Proline series decks - don't know how much they cost, but they've been running for about 5 years now and I don't recall them ever being out of service.
Hope this helps,
nao
#3 Brian Wells
Brian Wells
  • 438 posts
Posted 12 June 2005 - 01:29 AM
In case you're not already aware: editing from analog tape is fairly cumbersome.
#4 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 12 June 2005 - 10:51 AM
Thats cool. My video card has S-Video but i wonder if it would be input or output?
Ive only used the RCA video and monitor jacks on it. S-VHS would be a great way to go for me if I can.
#5 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 12 June 2005 - 12:07 PM
Yeah Ill have to buy a PCI card but theyre like 5 bucks on ebay.
#6 Brian Wells
Brian Wells
  • 438 posts
Posted 12 June 2005 - 02:24 PM
A word of caution...
The thing to remember is most home editing software is engineered for miniDV and Firewire and may not (or may?) be equipped with the proper codec's and interface to digitize from S-Video.
Premier may still support analog capture as I do recall cutting some Hi-8 on there back in the late nineties, but couldn't recommend it today with the current slew of miniDV equipment available. What you'd save on a camera, you'd likely spend on editing hardware.. And, even then it won't necessarily work right. Editing video on a home computer can be a real doozie!
Anyways, best of luck to you in your endeavors.
#7 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 12 June 2005 - 11:07 PM
Good thing I bought Adobe Premiere then lol. I should be able to pull off the computer I think. I guess I dont really know but my computer has 3 512 mb memory cards in it and is fairly new. I just formatted it too so 2 blank drives would that be able to handle it?
Edited by Aphix, 12 June 2005 - 11:08 PM.
#8 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 12 June 2005 - 11:56 PM
What about the Panasonic WV-3260? Is that digital?
#9 Landon D. Parks
Landon D. Parks
  • 1917 posts
  • West Chester Township, Ohio
Posted 13 June 2005 - 01:28 AM
Why dont you just go buy a $200 MiniDV camera is your gonna do SVHS... I know a new SVHS will run every bit of this! Circuit city was a selling a cheaper Panasonic model w/ firewire out and more than enough features in camera to make an ok movie... The quality will be a lot better than SVHS...
SVHS is an old format, while they still make camera for it, and they are cheap, but you will run into some trouble in editing.
Unless your doing a linear editing (tape to tape) youll have some problems in getting the footage into the computer for the NLE.
My advice is this: Since you said something about buying from Ebay, look on ebay for a good minidv camera for under $200.00! If Circuit city has them new for that, Im sure e-bay will have the same model...
Circuity city has the Samsung SC-D353 new for $285.00 online (http://www.circuitci...hoppingcart.jsp) or If you wanna buy used from e-bay: http://cgi.ebay.com/...7522824264&rd=1 pretty good camera for $102.00 in MiniDV... However, as Im sure you know prices on Ebay change all the time, so its best to check for yourself.
I would not buy any camera under a MiniDV for any kind of movie work. The way I see it is $200 is not to much to pay for a camera, since if you go analog you'll have to find someway to capture the footage into the computer, then you have two options: Either have software that can capture analog, or run the analog through another program to get a complete file in Quicktime or WMV format, then load that file into the NLE.
Again, It's just more difficult to go analog, and in the $30 dollars you saved from shooting analog you will might as well have paid yourself $500 for all the time and extra trouble it took to get the footage to the computer.
NOTE: You may also check into Digital8, which is the digital version (complete with firewire) of the Hi-8 analog format. While the resolution is still only like 200 lines of resolution compared to MiniDV's 525 (us) and 625 (uk), it might be a medium point in your problem... Digital8 cameras are somewhat cheaper than MiniDV... But its still unlikly you'll find any new camera for under $200, even in SVHS... E-bay may have some Digi8's for $100-$150 used though....
Just my advice, GOOD LUCK!
#10 Phil Rhodes
  • 12162 posts
Posted 13 June 2005 - 06:06 AM
Why? It's done all the time. Probably the easiest way to do it is with a firewire convertor, so it might be more expensive and not look as good in the end, but I can't say you'd have any "problems" making it work.
No. This betrays a fundamental misunderstanding of how video systems work.
What I think you're trying to refer to is the usual way of measuring video resolution, which is in vertical lines. All DV formats - and Digital8 is a DV format using the same codec as miniDV - will resolve up to 720 vertical lines of information as a tape format, depending heavily on the rest of the picture's content. The camera may or may not resolve to that level - most D8 cameras are or were rather shoddy - but it'll be a hell of a lot more than 200 lines.
When you compare this to the 525/625 line counts, you're referring to the number of scan lines in the picture. This is constant across all formats within a given standard; NTSC devices always scan 525 lines, irrespective. VHS does; Digital Betacam does. If it doesn't scan 525 lines, it isn't NTSC.
OK?
Phil
#11 Landon D. Parks
Landon D. Parks
  • 1917 posts
Posted 13 June 2005 - 10:44 AM
Ok, but still... Digital8 id better resolution and picture quality than SVHS, and MiniDV is better resolutionand picture quality than Digital8... I know that for a fact.
And while you do say its easy to get the footage into the computer in analog... it may be, however note you will have to buy a "converter" which will add on to the money that you have to spend...
I just dont see why you would pay the same for an analog system that you could for a digital one... analog is a pretty much dead format these days..
on digital:
The sound is better, the picture is better, it has more resolution, the tapes are better, most of the times the lenses are better, analog loses picture quality everytime you view it / play untill it's digitized, ect, ect, ect... I could go on about more of the let downs to analog...
My feeling is this: save the extra $50.00 to shoot digital instead of analog (if its even that much more, which in the end I doubt)...
Edited by Landon D. Parks, 13 June 2005 - 10:48 AM.
#12 Phil Rhodes
  • 12162 posts
Posted 13 June 2005 - 01:20 PM
No, it isn't. As a tape format it's exactly the same thing.
Despite the fact that you're clearly incorrect on this point, let's humour you for a moment: exactly how do you know this?
Phil
#13 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 13 June 2005 - 01:21 PM
Again, MiniDV format is no better or worse than Digital 8. They're both consumer level DV, merely on different tapes. D8 records on Hi8 tape, and was invented By Sony during the early DV era to simplify tape supplies at Target and such stores that were already stocking Hi8 tape. Now that DV tapes are easier to find at the Walmarts of the world, D8 isn't as useful as it once was.
No doubt you can find better MiniDV than D8 cameras, but that is merely a decision by Sony to segment the marketplace.
#14 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 13 June 2005 - 02:21 PM
While you can probably get a 2/3' broadcast SVHS camera for very little money
And the intial output image will look very good--like many prosumer MiniDV cams
The question you should be asking yourself how can you minimize the deterioration
Of image quality in the post process--any analog copy will have generational loss.
Any copy that you make for editing will suffer an image loss
This is what makes S-VHS an unsuitable format for filmmaking..
It just not good for the archives at all.
If you can figure out a way to digitize the footage without losing image quality...
Perhaps you might have a chance as making good use of SVHS...
But I'm sure it'll make it just as expensive as MiniDV.
If you don't mind all the headaches recommend you use MiniDV...
You can probably rent a XL2 for the price of getting of a good SVHS camera.
Eitherways
GoodLuck
#15 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 13 June 2005 - 05:28 PM
Ok so dont mess with SVHS. Does quality in miniDV change alot from camera to camera though?
#16 Landon D. Parks
Landon D. Parks
  • 1917 posts
Posted 13 June 2005 - 07:58 PM
Ok, the knowlegfe I gained on Digi8 is what I was told @ circuity city (and they dont work on commision)...
and:
Yes, quality differed from miniDV camera to MiniDV camera. Not in the resolution or compression areas, but in the lense / features areas.
The cheaper MiniDv camera will have less features than a more expensive one. You will also find the optics not as great as in some high model cameras. I know the Canon I was gonna buy once (forgot the model #) was like $550.00 and had Carl Zeiss lens, with a wide angle converter included. It also had more than enough features to edit your movie right in the camera.
The one I ended up getting thoough was the Pansonic, which was $200 (thats all I could afford) and it did well, very well in fact. I dont make use of the "in-camera" features to much, so that was not a problem. And the lense included with the Panasonic was fairly good, although I don't think it was a Zeiss lense...
Moral of this story: If possibe go MiniDV, maybe Digi8 (which I THINK will limit you to Sony cameras)... VHS and SVHS are so old now, that there more trouble then they are worth.
PS) Something tells me most of the older SVHS and VHS camera's have much less pixels than the newer MiniDV cameras, and also the CCD may not be as good as in the newer cameras.. Thats not to say they still dont make SVHS cameras, cause I think they do...
What I'm trying to get over here is this: A new SVHS camera will run just as much as a lower end MiniDV camera, which will be just as good if not better than the SVHS camera.
Is anyone wanted to argue that SVHS is just as good as MiniDv??? Cause I'm ready to fight it to my death bed!
Edited by Landon D. Parks, 13 June 2005 - 08:00 PM.
#17 Phil Rhodes
  • 12162 posts
Posted 13 June 2005 - 08:03 PM
The prosecution rests.
#18 Landon D. Parks
Landon D. Parks
  • 1917 posts
Posted 13 June 2005 - 08:39 PM
Defense calls for mis-trial!!!! Any judge would through this out like yesterdays table scarps, lol :rolleyes:
Edited by Landon D. Parks, 13 June 2005 - 08:41 PM.
#19 Brian Wells
Brian Wells
  • 438 posts
Posted 14 June 2005 - 02:04 AM
An older AG5600 (is that it?), a bigger kind of camera may be the same price used as a newer handheld miniDV camera. I haven't looked and am quite possibly wrong here. The advantage of the bigger camera (compared to a small miniDV) is better sensitivity because it would use a larger CCD chip for the image sensor. The rule of thumb is the larger the "chip" the better the sensitivity to light. So, in other words, you would need more light when shooting 1/6" miniDV vs. 2/3" S-VHS, at least in theory anyways. The S-VHS would likely require some additional editing hardware (as mentioned, a simple ADS Pyro analog-to-firewire converter box would be fine) and bring very acceptable results as an aquisition tool, probably better in some ways than a small miniDV. However, I don't think you would want to master your work on S-VHS, you'd probably want to save finished copies of your videos on miniDV or DVD as they'll look better for a longer period of time than analog tape. (again, just reiterating what has already been said) Digital8 and miniDV both handle digital video in the exact same way. No matter where you draw the line, you could always spend more. If comparing a Compact S-VHS camera (are they making those... AGAIN?!) to a miniDV, the miniDV would be a "no brainer" For you, go with miniDV. You will have problems in post no matter what you record on. It's murphy's law, if you what that is.
Edited by Brian Wells, 14 June 2005 - 02:07 AM.
#20 Aphix
Aphix
  • 17 posts
  • Eagle, Nebraska
Posted 14 June 2005 - 09:29 AM
Thanks for the help guys.
