High speed shooting hospital - led and overhead flourescents?
#1 Ed David
Ed David
  • 39 posts
  • NYC
Posted 22 August 2016 - 09:12 AM
Hi guys - apologize if this has been asked before
doing a high speed 240 FPS shooting in an existing hospital -
question - can I switch out the overhead tubes for kino bulbs and not have flicker?
and can I use LED lighting like litemats?
what can i get away with besides flicker-free HMIs bouncing into ceilings, etc etc?
thanks!
Ed
  • 20346 posts
Posted 22 August 2016 - 09:36 AM
Changing out the tubes won't help because it's the ballasts that determine the flicker rate.
Your flicker-free ballasted lights should be fine but it wouldn't hurt to test.
#3 Ed David
Ed David
  • 39 posts
  • NYC
Posted 22 August 2016 - 09:30 PM
Thanks David!!!
#4 Nima Khazaei
Nima Khazaei
  • 25 posts
  • P.A.
  • San Francisco
Posted 23 August 2016 - 04:08 PM
Your Litemats should be flicker-free too.
http://www.litegear....e-flicker-free/
I've yet to have any flicker issues with any of my LED lights. I suspect most cinema LEDs use either constant-current regulation for dimming, or frequencies high enough to keep them safe for all but the most extreme of frame rates.
My inclination would be to make good use of HMIs, just given the 3-4 extra stops needed for 240 fps.
#5 Phil Rhodes
  • 12338 posts
Posted 23 August 2016 - 06:12 PM
I'd be a little (a lot) cautious of HMIs. I've seen tests in which they caused serious problems on high frame rate stuff, even with expensive ballasts switched to flicker-free mode.
