Best stand to use for height work?
7 replies to this topic
#1 Jay Young
Jay Young
  • 512 posts
  • Lexington KY
Posted 22 August 2016 - 10:06 AM
I need a 1200w PAR HMI 30-feet in the air, without renting a condor/genie.
Will a Mombo-combo hold a 25lb lamp head, 30 feet in the air, with guy lines and a bunch of shot-bags?
I don't have budget to rent a condor, and I'm in the middle of nowhere?
The guy at the rental house is being a real [genuine people person]... Thoughts?
I have a Sky-High here, but that only holds 50lbs and I feel like the Mombo-combo would work better as it has a much larger footprint and built in mounts for tying off guy wires.
Thoughts?  Is there a better light stand to use?
#2 Michael Rodin
Michael Rodin
  • 266 posts
  • Moscow
Posted 23 August 2016 - 05:12 AM
Look into wind-up stands. Italians of Avenger made some of the tallest, i.e. the Long John Silver.
#3 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 23 August 2016 - 05:44 AM
4 riser Mombo Combo only goes to about 23'.  The masthead knot can be used to add guylines to any stand.
I'd second the suggestion to rent a crank up stand.
#4 Jay Young
Jay Young
  • 512 posts
  • Lexington KY
Posted 23 August 2016 - 05:57 AM
Thanks. It's been suggested that I use scaffolding as well.  I'm sure we will get what we need accomplished!
#5 JD Hartman
JD Hartman
  • 1809 posts
Posted 23 August 2016 - 06:22 AM
Scaffolding that tall would need to be attached to the building.  More costly than a stand.  Would the towable "baby" condor rented by Home Depot be an option?
#6 Stuart Brereton
Stuart Brereton
  • 3491 posts
Posted 24 August 2016 - 11:03 AM
Those Avenger stands only go to around 18 feet, albeit with a larger payload than a Mombo, and they are huge. Last time I rented one, it came on it's own muscle cart.
#7 John David Miller
John David Miller
  • 127 posts
  • Grip
Posted 29 August 2016 - 07:17 AM
I don't know of a stand that goes 30' in the air.
If you are near a Home Depot, see if they have a "Towable 30' Boom Lift." This will probably be cheaper than renting and delivering a tall stand that won't get you the height you are looking for without scaffold.
#8 Jay Young
Jay Young
  • 512 posts
  • Lexington KY
Posted 29 August 2016 - 09:12 AM
I opted for 3 sections of scaffolding and a three riser stand.  It's going in the forest with plenty of big trees to anchor things too - I guess, the key grip says its fine.
That Home Depot 'towable boom lift' is awesome!  I didn't even know that existed.  I'll definitely be using that in the future!
