Need help exporting timelapses for post
No replies to this topic
#1 Yash Lucid
Yash Lucid
  • 72 posts
  • South Africa
Posted 29 August 2016 - 05:26 PM
Hi.
I have two workflows that I need some advice on. I'm on Windows
Workflow 1 (No AE needed)
1. Import RAW photo sequence into LrTimelapse
2. Process images
3. Export to lightroom
4. Grade
5. Export to ProRes 444 using LrTimelapse plugin integrated into LR
Workflow 2 (AE Needed)
1-4 above
5. Import RAW sequence with updated metadata into AE
6. Do post work, cleanup, vfx, etc
7, Export
Now, with Step 7, I cannot export ProRes from AE on Windows. What is the equivalent? I used DNxHR RGB 444 however the file size is far bigger, what else can I use that is equivalent? The colorist will need to grade to match their Red Epic grade.
