Skypanel front diffusion safety
10 replies to this topic
#1 andrew ward
andrew ward
  • 269 posts
Posted 05 September 2016 - 07:59 PM
What happens if you remove the intensifier or diffusion panel from the front of an Arri Skypanel?
Is it a death blast like Cyclops?
Its something to do with blue leds being harmful like an Area 48 or something isnt it?
Just wondering...
#2 Phil Rhodes
  • 12370 posts
Posted 06 September 2016 - 03:30 AM
It turns off. Usually.
I had some on demo recently and one of them was a prototype which didn't. Presumably the safety switches are actually installed on all the real ones.
They said that it wasn't dangerous as long as you didn't state into them, but I preferred caution. Those are some very, very, very intense points of light in there, and I would avoid looking at them for fear of eye damage.
#3 andrew ward
andrew ward
  • 269 posts
Posted 23 September 2016 - 10:24 AM
Be good to get more punch out of it. Theyre not bright enough.
#4 Phil Rhodes
  • 12370 posts
Posted 23 September 2016 - 11:37 AM
Personally I prefer non-diffused LED panels. You can always diffuse them; you can't un-diffuse something that's already got basically 216 diff in front of it.
That said if you pull the diffuser on a SkyPanel, you'll just get lots of shadows. The emitters aren't in any sense directional.
#5 JD Hartman
JD Hartman
  • 1802 posts
  • Edison, N.J. U.S.A.
Posted 01 October 2016 - 03:50 PM
Fired up one the other day, no diffusion.  Very bright and harsh, no safety switch on the unit that I could find.  Based on the cautions in the operating instructions, probably emits a lot of UV as well.
#6 Phil Rhodes
  • 12370 posts
Posted 01 October 2016 - 04:13 PM
Hmm. Arri told me they should all have the safety switches, so either you've got faulty ones (more probably) I've been lied to.
Certainly some of the ones I had on demo did have switches. I think it was the s30 that didn't. What were you using?
#7 JD Hartman
JD Hartman
  • 1802 posts
Posted 03 October 2016 - 11:16 AM
It was an S60.
#8 Phil Rhodes
  • 12370 posts
Posted 03 October 2016 - 12:36 PM
Hrm, that's a bit disquieting. I'm not sure what else to say, really. Did you ask the supplier?
#9 JD Hartman
JD Hartman
  • 1802 posts
Posted 03 October 2016 - 01:56 PM
I would have to ask ARRI, since they were just unboxed.  Don't have the time just yet.  I see nothing in the user manual, etc. that would indicate that they have any kind of safety switch.
#10 Phil Rhodes
  • 12370 posts
Posted 03 October 2016 - 02:02 PM
Some of those I had on demo certainly did.
#11 Jean Gonzales
Jean Gonzales
  • 37 posts
  • Electrician
  • Antwerp, Belgium
Posted 15 October 2016 - 09:32 AM
S-30, S-60 none of them turn off when you remove the diffuser. Have done this many times. Didn't get my hands yet on the S-120.
Edited by Jean G, 15 October 2016 - 09:34 AM.
