Removing Sprockets on a Bolex H16?
#1 Gabi Bucataru
Gabi Bucataru
  • 10 posts
  • Chicago, USA
Posted 08 September 2016 - 08:20 PM
Hi gang!
So I am taking the crazy risk of filing one side of tooth from my Bolex H16 to be able to accept R1 film (one side perforation  film). I did stuff like this before, not on a camera, I have some basic tool & dye filing knowledge, tools etc.
The question I have - ho on Earth do you take those sprockets out?
I took out the two screws that are keeping in on the axle but they are still not popping out. Both of them. I don't want to force anything, so I was wondering if they should come off together with the loop making mechanism also?
any tips more than welcome!!
thanks a lot!
Gabi
#2 Gregg MacPherson
Gregg MacPherson
  • 1992 posts
  • New Zealand
Posted 08 September 2016 - 10:02 PM
Dom Jaeger knows a lot about bolexes and often drops in to a thread like this and helps out.  Hold off filing metal as long as you can.
Till then,  is the whole sprocket assembly a stack,  with the sprocket itself machined from a thin plate?  If so,  why not dissassemble that stack and replace the sprocket with a non sprocketed spacer.
#3 Simon Wyss
Simon Wyss
  • 1612 posts
  • Near Basel, Switzerland
Posted 09 September 2016 - 02:03 AM
Simply order a pair of one-side sprocket drums at Bolex International.
They should be mounted by a specialist because it takes a gauge for the correct height.
You could have your camera revised at the same time. Cleaning, lubricating, adjusting
From the fact that you have an H-16 with double-side sprocket drums we know that it
must be at least 60 years old. Time for a checkup
#4 Gabi Bucataru
Gabi Bucataru
  • 10 posts
  • Chicago, USA
Posted 09 September 2016 - 09:15 AM
Thank you Simon!!
Precious advice.
Do you by any chance of Bolex servicing places in the USA?
thanks,
Gabi
#5 Simon Wyss
Simon Wyss
  • 1612 posts
Posted 10 September 2016 - 02:50 AM
Seems that you omitted a word.
http://www.bolexrepair.com/links.html
Jean-Louis Seguin, Montreal, Canada
#6 Gabi Bucataru
Gabi Bucataru
  • 10 posts
  • Chicago, USA
Posted 13 September 2016 - 02:25 PM
Thanks Simon!
Looks like they do not repair any H16 series but I found that http://www.bolexusa.com/ does. I already chatted with them. $25.00 a piece.
thanks for the help!
Gabi
