camera running sound
#1 L K Keerthi Basu
L K Keerthi Basu
  • 128 posts
  • india
Posted 14 June 2005 - 12:12 PM
What is the running sound level of a movie camera in decibels? From what distance is this measured? What is the recommended level for the spot recording(sound)?
I think this should be known to a cinematographer because one of the sound recordist has asked me about this.
L.K.Keerthibasu
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 14 June 2005 - 12:54 PM
  L.K.Keerthibasu
<{POST_SNAPBACK}>
Camera manufacturers usually publish noise data for their cameras. I believe they are measured in normal operational configuration (with lens, with film) in an anechoic chamber with the microphone 1 meter in front of the camera. Not sure of the "weighting factor".
For example, here is the data for the Aaton XTR:
http://www.aaton.com...tr/xtrspecs.php
Noise level 20 dB -1/+2.
And the Aaton 35-III:
http://www.aaton.com.../35/35specs.php
Noise Level 4-Perf: 30 / 33 dB. 3-Perf: 24 / 26 dB
Just for reference, here are typical noise levels:
http://www.chs.ca/in...ise/levels.html
#3 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 14 June 2005 - 01:45 PM
Pretty much any recent 35mm sync sound camera will run at 20dB. This includes the Arricam Studio, 535, Panavision Millenium, Platinum among others.
#4 Phil Rhodes
  • 12161 posts
Posted 14 June 2005 - 03:13 PM
However, any camera you're likely to actually end up using...
Phil
#5 Rolfe Klement
Rolfe Klement
  • 668 posts
  • London | LA
Posted 14 June 2005 - 04:13 PM
Not sure if you have any setups planned with higher frame rates - but the higher the FPS : the higher the noise - so most published ratings are for 24|25 fps
thanks
Rolfe
#6 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 15 June 2005 - 03:21 PM
All cameras are different, and they're different depending on if they've been lubricated recently, etc.
I just lubed my Canon Scoopic M, and it got about 1/2 as loud!
I think you're only going to find specs for recent high-end film cameras.
The confusing thing is, the listings of decibel levels are not that helpful, because different things will sound louder or more quiet, depending on the frequencies present.
The human ear is more sensitive to certain frequencies, and unfortunately, camera noise tends to fall into those bands!
For instance, an eggbeater might have a similar decibel level to someone rubbing their shoes across a carpet, but guess which one you will think is more intrusive in your dialog tracks?
The other problem is that the frequencies from camera noise that you need to notch out in post (if you can't eliminate them on-set) significantly affect the fidelity of dialog tracks, because much of the human speech is in those same frequencies, so it gets the same treatment, thereby sounding really unnatural.
Matt Pacini
