Best F-Stops for Expired Film
Kodak Film Exposure
15 replies to this topic
#1 Nate K
Nate K
  • 10 posts
Posted 30 September 2016 - 06:51 PM
I recently purchased the expired Kodak Film Stock listed below and would like any suggestions on the best F-Stops for exposure. I plan to telecine to 1080p or 2K. Will be using a K-3 16mm camera.
7246-250D
7274-200T
7279-500T
7289-800T
7298-500T
Nate
#2 Tyler Purcell
Tyler Purcell
  • 4246 posts
Posted 30 September 2016 - 07:05 PM
I'd drop off the oldest roll to FotoKem and have them do a fog test. That will tell you how out of range it is.
#3 Nate K
Nate K
  • 10 posts
Posted 30 September 2016 - 07:47 PM
Thank you so much Tyler! Do you have any idea what the cost would be?
#4 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 30 September 2016 - 08:58 PM
All of those stocks are fairly ancient, and will exhibit a fair degree of fogging, depending on how they've been stored. Your best bet is to send them to a lab for clip testing. Be aware that the lab will almost certainly tell you that the stock is unusable, as they don't want to be liable for poor results.
Try overexposing by  at least a stop. If you accept that you are not going to get a perfect 'normal' image from such old stock, and you can find a good telecine colorist, you may still get images that you are happy with.
#5 Kenny N Suleimanagich
  • 902 posts
Posted 01 October 2016 - 12:06 AM
Apparently some scenes of the new tent pole HBO series "Westworld" used 5245 in the pilot. I wonder what they rated at.
#6 Tyler Purcell
Tyler Purcell
  • 4246 posts
Posted 01 October 2016 - 02:12 AM
I think it's $25 dollars? Something like that.
Knowing the fog level, will allow you to understand HOW many stops to over expose.
I would also experiment with over and under exposing so you know the limits vs noise level.
I have some Fuji stock from the late 90's that's been in the freezer since original purchase and it came out very nicely one stop over, even though the fog test said it was pretty bad.
#7 David Mullen ASC
  • 20176 posts
Posted 01 October 2016 - 06:50 PM
I think it's a mistake, I worked on the show and saw the camera reports from various episodes -- and some Vision-3 50D was used, but I didn't see anything listing EXR 50D.  The Kodak article itself says 5245 in the main text but 5203 in the summary at the end. I could be wrong and maybe some EXR 50D was dug up out of a freezer somewhere.
#8 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 01 October 2016 - 07:30 PM
It does say 5245 in the ICG Magazine as well. Paul Cameron is quoted as saying "it's a really rich stock that has that Marlboro feel." ICG does say that 5207 was favored by the other DPs on the show. Perhaps they used 5245 only in the pilot.
#9 David Mullen ASC
  • 20176 posts
Posted 01 October 2016 - 08:01 PM
It's just odd considering EXR 50D 5245 was discontinued in 2006. But it's possible I suppose.
#10 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 02 October 2016 - 12:30 AM
I think a lot of these articles work from the same press release, so who knows?
#11 Kenny N Suleimanagich
  • 902 posts
Posted 04 October 2016 - 12:06 AM
Was '45 the last EXR stock in production? That's a pretty large overlap into the Vision/V2 era.
#12 David Mullen ASC
  • 20176 posts
Posted 04 October 2016 - 11:18 AM
I don't there was a Vision2 100T so either '45 or '48 was the last EXR stock...
#13 Kenny N Suleimanagich
  • 902 posts
Posted 04 October 2016 - 11:49 AM
Kodak just updated the articles with a correction. It was 5203, not 45.
#14 Nate K
Nate K
  • 10 posts
Posted 28 October 2016 - 03:08 PM
Thank you Tyler and Stuart your information was spot on! :D
#15 Adam Frisch FSF
Adam Frisch FSF
  • 2041 posts
  • Los Angeles, USA
Posted 12 November 2016 - 02:00 PM
I would not send them for fog testing. When you send for fog testing, they will either pass or not pass very narrow definitions. And if it doest pass, they normally just throw it away. And just because it won't pass, doesn't mean you can't shoot on it. I've shot many, many times on film that not only was expired, but that the lab condemned.
Trick is to overexpose. Thankfully film can take a lot of over-exposure and still be fine. I would start with at least 1 stop overexposure for any expired film. Then the general rule is add 1 stop for each decade of expiration. Obviously, you will reach a point where the stock might be too old, where the radiation all around has has built up the fog levels too much.
Here's a good article from a stills magazine on subject:
http://www.popphoto....ng-expired-film
#16 Tyler Purcell
Tyler Purcell
  • 4246 posts
Posted 12 November 2016 - 02:36 PM
Hey Adam, FotoKem here in Los Angeles, doesn't throw anything away or damage anything. The film comes back with a piece of paper that tells you how far off it is and most importantly, if one or more of the channels is different then the others. You can see what each layer is suppose to be and there is a little chart that tells you based on a certain percentage, how much over-exposing you'll need to do in order to get past the fog level.
I personally feel it's an important step because if you're shooing something critical, you NEED to know if one of the channels is way off for some reason AND exactly how much to over-expose for. It's worth the money because sometimes, the film will be totally toast and way beyond the ability of correcting.
I just did a fog test on some Fuji stock that was from the 90's and it was barely acceptable. It came out great, though it was VERY noisy, even with over exposing.
