How high can I take shutter angle before extra motion blur?
#1 Roger Alexander
Roger Alexander
  • 43 posts
  • Atlanta
Posted 01 October 2016 - 09:30 AM
Sometimes when my scene is too dark and I want to brighten it up without raising the ISO (and without adding more light) I will slightly raise the shutter angle from 180 degrees to like 225. Conceptually, I know that 180 is like the standard and doubles your frame rate. When you lower the shutter angle, the shutter speed is faster for that choppy look, and if you raise the shutter angle it slows the shutter speed and adds more motion blur into your shot. (Hopefully I don't have this backwards lol) My question is, how high (slow) can I move my shutter angle above 180 before I start to notice extra motion blur in the image? My goal here is to raise the shutter angle as much as possible to brighten my scene more without a noticing the extra motion blur. I plan to run some camera tests myself but I was curious if there some sort of formula or pre-completed tests on this?
#2 Jay Young
Jay Young
  • 498 posts
  • Lexington KY
Posted 01 October 2016 - 10:00 AM
Why do you not want to add more light?
#3 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 01 October 2016 - 10:05 AM
It depends on your scene. If there is no fast movement, a wider shutter angle can be unnoticeable.
#4 David Mullen ASC
  • 20191 posts
Posted 01 October 2016 - 06:47 PM
Obviously any increase in shutter time will increase motion blur, so how much you notice that depends on how much motion is in the shot and how sensitive you are to such a change -- there isn't some crossover number where it becomes noticeable, it just gets gradually more obvious the more you increase the shutter time depending on the amount of motion in the frame.  If it is a static shot, no motion in the frame, you could shoot with a 360 degree shutter angle and no one would be able to tell.
You just have to judge your scene and how much movement there is in it, both subject-wise and camera-wise.
#5 Robin R Probyn
Robin R Probyn
  • 2354 posts
  • Tokyo
Posted 01 October 2016 - 08:18 PM
Apart from just plain not having enough lights ..  there are some locations that wont allow any lights at all..  Ive had Art galleries.. Museums .. some hospitals..alot of labs.. ... its alot better in the LED days now.. but their rule books haven't always been up dated..
