Aaton LTR54 with daylight spools
#1 Seth Lawrence
Seth Lawrence
  • 7 posts
  • 2nd Assistant Camera
Posted 04 October 2016 - 04:16 PM
I have a producer who has some 30m daylight spools meant for a bolex that he would like to use with an Aaton LTR 54. I'm wondering if it would be possible to adapt these to the camera short of simply having them put on cores. According to the manual at the link below (on pg. 14) it's simply a matter of removing a screw. Just wondering whether anyone here has any experience with this, or if this manual is referring to a daylight spool I'm not aware of (i.e. a 100 ft version of the A-minima 200 ft reels or something like it). Thanks!
http://www.my16mm.co...aatonltrman.pdf
Edited by Seth Lawrence, 04 October 2016 - 04:18 PM.
#2 Robert Lewis
Robert Lewis
  • 180 posts
  • United Kingdom
Posted 04 October 2016 - 05:24 PM
Seth ... If you are referring to the standard metal black spools which Kodak and others use for 100ft rolls, these are a standard "daylight" spools which can be used on Bolex, Arriflex, and Aaton cameras, and very probably other cameras. They are quite different to those used on the Aaton a-Minima camera however, which was a special design for that camera and that camera alone, and cannot be used on other cameras.
I have an Aaton LTR54 camera, and I can assure you that the standard black 100ft reels referred to above can be used in the LTR54 with no difficulty whatsoever. I mostly use those reels.
The LTR54 is designed to take 400ft rolls of film which are wound on to cores as well as 100ft daylight spools, and as the manual says, to use the 100ft metal daylight reels you first have to remove the core centres by unscrewing the small screw. On withdrawing the mounting for cores you will find that the 100ft spools will fit on the shaft on which the core centre was mounted.
Both sides of the magazine are the same in so far as the precedure described above is concerned.
Regards.
  • 1
#3 Seth Lawrence
Seth Lawrence
  • 7 posts
Posted 04 October 2016 - 05:37 PM
Thank you for the detailed response!
