Super 8 crop factor
#1 Chris Burke
Chris Burke
  • 1765 posts
  • Boston, MA
Posted 21 October 2016 - 10:02 AM
Is the crop factor 5? As compared
to full frame still photography.
#2 Michael Lehnert
Michael Lehnert
  • 1097 posts
  • London, UK / Basel, CH
Posted 21 October 2016 - 10:36 AM
Almost 5.
The focal length multiplier from Super 8 (diagSuper8 [1:1.33] = 7 mm) to Full Frame 35 (diag24x36 = 43.3 mm) is actually x 6.19
Or x 0.16 the other way round.
#3 David Mullen ASC
  • 20414 posts
Posted 21 October 2016 - 10:37 AM
Just compare the dimensions -- if you want to compare horizontal field of view, Super-8 is 5.79mm wide and Full-Frame is 36mm wide, so that's a 6.2X crop factor (36 ÷ 5.79).
#4 Chris Burke
Chris Burke
  • 1765 posts
  • Boston, MA
Posted 24 October 2016 - 09:46 AM
Thanks. That explains why 7mm focal length doesn't seem that wide on S8
#5 Michael Lehnert
Michael Lehnert
  • 1097 posts
Posted 24 October 2016 - 10:19 AM
6mm would be the ideal wide angle for Super 8. The top production cameras by Beaulieu, Leitz, Bauer, and Nizo have that as the shortest focal length of their built-in or interchangeable vario lenses.
A 5mm prime, or indeed a 6mm or 7mm vario setting on any lens with the Schneider Kreuznach Superwide / Ultrawide Lens Type I/II/III or Type Nizo attached would get you down to 4.5mm - 5mm. But you would have to expect distortion in your shots that may be unacceptable if you don't look for that kind of aesthetic on purpose.
#6 Andries Molenaar
Andries Molenaar
  • 701 posts
  • Amsterdam
Posted 24 October 2016 - 02:28 PM
The Schneider UWL definitely does not fit/work with any lens. Oddly enough it mostly goes well with the Schneider zoom lenses :) Other types are better cross-checked before buying one.
Edited by Andries Molenaar, 24 October 2016 - 02:35 PM.
#7 Michael Lehnert
Michael Lehnert
  • 1097 posts
Posted 25 October 2016 - 07:39 PM
Huh? Any lens with such a working wide angle lens attached will go from 6-7mm down to 4.5-5mm. The laws of optics are usually brand-agnostic  :rolleyes: . To pick the right working configuration is frankly self-evident, isn't it?
